 Post subject: problems with regenerating translator
PostPosted: February 24th, 2007, 7:11
I tried to regenerate translator with pc3000pci and got Error 51/04. Drive is WD800JB-00ETA0. Does anybody know what that error means?
Here is pc3000pci log:
Techno mode key:
HDD geometry loading.................... : Ok
Cyl Count............................... : 87906
Head Count.............................. : 2
SPT..................................... : 820
RAM:
Zone allocation table................... : Ok
ROM version............................. : 77.3J.
SA FW version........................... : 77.3JW
Link table version...................... : 07.46.
Serial ROM:
Read ROM................................ : Ok
Heads configuration..................... : From map
Heads number............................ : 2
The number of heads in use.............. : 2
Disabled heads.......................... : No
Head map................................ : 0,1
Service area:
Modules table loading................... : Ok (Copy 0)
Configuration loading................... : Ok
Master Password......................... : "WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCWD"
User Password........................... : has not been set
Translation overlay checking (Copy 0)... : Module reading error : WD Techno Read Error C/H/S: -3/0/336 - Device Error Detected 59/40 (UNC)
Translation overlay checking (Copy 1)... : Module reading error : WD Techno Read Error C/H/S: -3/1/333 (15000 ms) - Drive is not ready
HDD ID reading.......................... : Ok
Translator regeneration
Regeneration method..................... : Use P-List only
Error 51/04
PostPosted: February 24th, 2007, 13:38
Looks like a damaged service area to me.
PostPosted: February 24th, 2007, 16:01
Is there any solution to recover the data when SA is damaged?
PostPosted: February 25th, 2007, 4:39
Yes check the service area for errors then add them to P-List .
PostPosted: February 26th, 2007, 12:08
:shock:
PostPosted: February 26th, 2007, 12:10
pixprit
If you have PC3000 you should know how to fix it.
Check out the manual, acelab forum etc. ;)
PostPosted: February 27th, 2007, 4:49
In my case it is not so easy, because regenerating translator didn't work and I can't format SA also. Modules reading is very unstable - sometimes (when hdd is cold) it reads most of the modules and sometimes I can't even read the P-list. Didn't found nothing about this case from WD manual. Fortunately I have a backup of all A-importance modules and other modules from another WD800JB-00ETA0. Any solutions?
PostPosted: April 5th, 2007, 17:07
check firmware zone please, check copy0 and copy1 about translator models, if them dosent same or damaged then repair them. you can use copy0 repair copy1, or 1 repair 0 if one of them good.
PostPosted: April 5th, 2007, 17:10
Or use Composite reading .
PostPosted: April 5th, 2007, 19:07
Too bad.
I wouldn't try to write anything into SA with such unstable heads.
You get ABORT error on regenerating translator because it can't read P-List. You can try to restore it but with such heads there is a chance you screw up and damage something else.
PostPosted: April 9th, 2007, 21:02
Hi you can try a PCB change with reads getting worse as drive warms up it is sometimes the ST chip on the PCB. You can get similar PCB and re-write with the one from original or change rom chip & try again. Sometimes it is a dodgy pre-amp chip on the armature and this won't help, but this has worked for some drives for me in the past.
I think ST is a sub company of Lucas
Users browsing this forum: Google [Bot] and 168 guests
