 Post subject: Raid 5 winhex error
PostPosted: February 28th, 2007, 12:42
I'm trying to assemble a raid 5 array, and I've got all the parameters, drive order, stripe size, etc.
When I launch it, it detects a NTFS partition, but when I open it I've got error 202 and the software shuts down.
Does anyone knows why this happen and what's the cause of error 202?
Thanks.
 Post subject:
PostPosted: February 28th, 2007, 13:36
Maybe 1 of the drives has bad sectors, so you should create separate images of each hard drive an then start winhex again.
 Post subject:
PostPosted: March 1st, 2007, 4:12
I've already done that and got the same problem with original drives and with image files.
 Post subject:
PostPosted: March 1st, 2007, 7:29
Have you tried Raid Reconstructor?
Just to 100% check you have settings and order correct?
Sean
 Post subject:
PostPosted: March 1st, 2007, 10:12
Yes, I've tried Raid Reconstructor too, and I have the NTFS partition, but then a lot of files are damaged.
 Post subject:
PostPosted: March 1st, 2007, 12:50
Problem solved.
With the last version of winhex problem didn't happened.
Thanks.
Users browsing this forum: No registered users and 53 guests
