 Post subject: Need Firmware WD 1200BB
PostPosted: February 19th, 2007, 2:05
Hello Everyone,
I need WD1200BB Firmware. More specific I need the 2F module for a
WD1200BB-18CAA0.
Since it's a B - module, I think any WD1200BB Firmware version should work. Thanks for the help.
email: quasimodo1 at gmail.com
 Post subject:
PostPosted: February 19th, 2007, 5:46
Check your e-mail.
It's not a full match but you can try it.
 Post subject:
PostPosted: February 19th, 2007, 9:47
dmarques,
This worked fine. Header in Module 2F was currupted.
Thank you very much.
 Post subject:
PostPosted: February 19th, 2007, 10:03
No problem.
Any time.
 Post subject:
PostPosted: March 19th, 2007, 12:07
next time you have this problem view one other module and write down the date and hex from another good module then click on 2F and click view, fix the date id and hex numbers, click on re-calculate checksum & re-write 2f to hd. re-check module and fixed! do this with copy 0 & copy 1 and you are good to go.
I think ST is a sub company of Lucas
Users browsing this forum: Majestic-12 [Bot] and 123 guests
