 Post subject: please help
PostPosted: March 7th, 2007, 13:16
i have a pc3000
and i have wd400eb-00cpf0
i make sa surace verification he make error
WD Techno Read Error C/H/S: -1/0/66 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -1/1/106 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -1/1/110 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -1/1/124 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -1/1/188 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -2/0/147 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -3/1/349 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -3/1/367 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -3/1/368 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -4/1/140 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -5/1/54 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -5/1/87 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -5/1/137 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -6/1/128 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -6/1/135 - Device Error Detected 59/01 (AMN)
WD Techno Read Error C/H/S: -7/1/92 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -8/0/556 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -8/1/5 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -9/1/160 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -9/1/529 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -11/1/155 - Device Error Detected 59/01 (AMN)
WD Techno Read Error C/H/S: -11/1/282 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -12/0/174 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -12/0/182 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -12/0/405 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -12/1/84 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -12/1/113 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -12/1/120 - Device Error Detected 59/01 (AMN)
WD Techno Read Error C/H/S: -13/0/0 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -13/1/109 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -13/1/113 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -13/1/144 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -13/1/170 - Device Error Detected 59/01 (AMN)
WD Techno Read Error C/H/S: -13/1/380 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -14/1/291 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -15/1/67 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -16/1/127 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -16/1/298 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -17/0/295 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -17/1/63 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -17/1/104 - Device Error Detected 59/01 (AMN)
WD Techno Read Error C/H/S: -18/1/292 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -18/1/336 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -19/1/30 - Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -19/1/317 - Device Error Detected 59/01 (AMN)
SA surface verification completed
my msn : Abo_Yousre@hotmail.com
please any one give me solution
 Post subject: What do U want
PostPosted: March 7th, 2007, 15:12
Data or disk what do you want.
DF
 Post subject:
PostPosted: March 7th, 2007, 15:53
I WANT repair disk i don't care about data
 Post subject:
PostPosted: March 7th, 2007, 16:47
run SA Structure test - it will give better idea ;)
 Post subject:
PostPosted: March 7th, 2007, 19:36
i sacn sa structure test
good
sa structure checking has been completed no error module
 Post subject:
PostPosted: March 8th, 2007, 10:02
ok
what's wrong with the drive then? :)
 Post subject:
PostPosted: March 9th, 2007, 3:16
i there are bad sectors on the drive u can try running Internal Format procedure .
Users browsing this forum: Google [Bot] and 49 guests
