 Post subject: must i replace rom when replace segate pcb?
PostPosted: June 11th, 2007, 19:31
salam alekm
i have segate hdd with bad pcb i replaced it with exactly same pcb but the hdd spin up but cant be read must i change parallel rom like we do in wetern in serial rom and not that i choosed pcb with same cpu is there any other parameters for choosing new segate pcb
 Post subject:
PostPosted: June 12th, 2007, 2:36
Same FW version required.
Otherwise U have to swap ROM provided that the board layout (CPU, motor controller...)is the same.
regards,
 Post subject: thanks too much
PostPosted: June 12th, 2007, 12:11
thanks too much
 Post subject: i switched the segate rom but hdd dosent spin up
PostPosted: June 14th, 2007, 5:50
 Post subject:
PostPosted: June 14th, 2007, 14:10
if hdd does not spin up it does not have anything to do with ROM , check motor for damage.
 Post subject:
PostPosted: June 20th, 2007, 22:20
try cleaning the pins on the connector block and bend the tabs up so they make better contact see if it will spin again. Either that or your donor was no good, or you missed something when you soldered the chip.
I think ST is a sub company of Lucas
