 Post subject: Needed help for WD800JD
PostPosted: March 10th, 2007, 6:12
Needed help for WD800JD (sata hard disk)
MDL WDC800JD-60LSA5
1 Need firmware
2 How to put it in Safe Mode
: : : : ( : SSC : PM2 :OPT1 : OPT2)
Problem:
Disk when power on starts to knock and then power goes off: I have Firmware ( WD800JD-75LSA0 ) I think it will do but I want guidance from the Gurus. how to put in Safe mode and will the ( rom ) if i rewrite work with the needed firmware with the firmware and rom i have
Thanks and regards
DF
 Post subject: WDC- little success
PostPosted: March 10th, 2007, 6:44
Respected Gurus
I have done some progress
Progress:
What it shows : After putting drive in safe mode (i have completed this part). When i run pc3000pci, in kernel it detects itself as Sabre58 and here is the log
Techno mode key:
Tech on................................. : Ok
ROM:
ROM reading............................. : Ok
Heads number............................ : 2
Heads number in use..................... : 2
Switched off heads...................... : No
Head map................................ : 0,1
Now I am waiting for the correct firmware / rom although i have for WDC800JD-75LSA0. Should I go with it if I don't get any help.
Waiting for Help
DF
PostPosted: March 11th, 2007, 20:10
In this case there is nothing to do with the firmware, but with everything else (pcb, heads, preamp).
 Post subject: Thanks
PostPosted: March 11th, 2007, 23:58
Thank you sir.
DF
 Post subject: Re: Needed help for WD800JD
PostPosted: September 30th, 2012, 9:36
darkfroce1,
Where you able to resolve the issue with the WD800JD-75LSA0? I replaced heads 3 times and even if you but the head back on the original donor it would not work... I think it has to do with the screw that is located on the top, it maintains the alignment of the heads, what did you find out on that?
PostPosted: September 30th, 2012, 13:18
Hi, I don't remember it. its a too old case.
DF:)
DF :)
www.datatracksystem.net
Users browsing this forum: No registered users and 92 guests
