 Post subject: Cleaning Heads. ?
PostPosted: March 24th, 2007, 2:03
Hi everyone
I need to clean heads on a Samsung SP0802N
Is there a prefered chemical to use?
Not sure if i should use Alcohol or something similar to give them a clean.
Does any one know the correct cleaning method if there is one ?
Cheers
 Post subject:
PostPosted: March 24th, 2007, 2:16
Clean heads or platters ?
 Post subject:
PostPosted: March 24th, 2007, 2:18
Hi rameez
how to clean both would be good.
But mainly how to clean heads.
thanks
 Post subject:
PostPosted: March 24th, 2007, 2:40
There is no situation where u should clean heads plus heads are too sensative to clean . Only thing i have done is clean platters .
 Post subject:
PostPosted: March 24th, 2007, 2:52
Ok
What would be the best way to clean platters?
Cheers
 Post subject:
PostPosted: March 24th, 2007, 7:38
use Alcohol works good for me .
 Post subject:
PostPosted: March 25th, 2007, 4:21
yes , and one more thing alcohol cannot clean scratches on platters , it is
just used for finishing of the job after heads or platters have been changed to remove any fingerprints or any small particle that may have come during work .
Users browsing this forum: Google [Bot] and 193 guests
