 Post subject: Maxtor showing up as a 128.0 GB
PostPosted: March 25th, 2007, 20:44
I have tried searching for an issue related to hard drives showing up as 128.00 GB but have not found any topics.
I currently have a: Maxtor MaXLine III 7L300S0 300GB 7200 RPM Serial ATA150. I have updated computers but when I plug my hard drive in... and when I click on <Manage> it shows up as a 128.00 GB drive with 154.47 GB Unallocated.
I am running SP2 with an ASUS P5VD2-X board: both of which support 48 bit LBA's. It was suggested to me that my new BIOS has different geometry translation and will not be able to read the hard drive. Is there any truth to this?
I have tried downloading a program called "Recover My Files" - which IS able to see the data, but when it copies the files over... most of everything is ... incomplete? For example, if its an audio file- I can only get HALF of the files to play properly.
Is there any other ways of repairing this drive without losing the data? Lunch is SO on me if anyone can figure out how :S
PostPosted: March 25th, 2007, 21:37
use MHDD and NHPA command, read documentation first
PostPosted: March 26th, 2007, 4:42
MHDD is not giving me the option of selecting my SATA drive. I can only see the primary IDE drive.
*EDIT*
I tried both the PORT command and SHIFT + F3.
What is the significance of the PC3000 (?) option that is blank?
PostPosted: March 26th, 2007, 7:50
You should turn off AHCI mode on your motherboard for SATA controller if it set
PostPosted: March 26th, 2007, 18:09
My JMicron RAID contr in my BIOS was set as <IDE> (but there is an option for <AHCI>) but I disabled it altogether.
Still MHDD does not see any of my SATA drives.
PostPosted: March 26th, 2007, 18:30
use victoria for windows to scan this hdd .
PostPosted: March 26th, 2007, 18:33
EDIT: I found Victoria 4.1- and when I push the "PCI Scan" it gives me the following list:
VIA / ID 0591*
VIA / ID 0591*
VIA / VT82C571 IDE
VIA / VT82C571 IDE
197B* / ID 2363
197B* / ID 2363
EDIT: Okay it found the drive, its scanning...
And also- thanks in advance for helping me through this- it is much appreciated.
PostPosted: March 26th, 2007, 22:12
Here are the results of eventlog.txt from Victoria program:
2:43:04 : Starting Victoria 4.1, CPU frequency: 2533,00 MHz, Windows XP found.
2:43:11 : Starting Victoria 4.1, CPU frequency: 2532,97 MHz, Windows XP found.
2:43:11 : Select SECONDARY port: base=170h, alternative=376h
2:43:13 : Waiting of readiness... Drive is ready
2:43:13 : Get passport... OK
2:43:13 : Model: WDC WD800BB-00CAA1; Firmware: 17.07W17; SN: WD-WMA8E4274287; Capacity: 156301488 LBAs
2:43:15 : Waiting of readiness... Drive is ready
2:43:15 : Get passport... OK
2:43:15 : Get S.M.A.R.T. command... OK
2:43:15 : SMART status = GOOD
2:43:17 : Waiting of readiness... Drive is ready
2:43:17 : Get passport... OK
2:43:17 : Recallibration...
2:43:17 : Recallibration... OK
2:43:17 : Starting surface scan, LBA=0..156301488, sequential access, timeout 10000ms
2:43:20 : Command interrupted by user!
2:45:42 : Starting Victoria 4.1, CPU frequency: 2533,00 MHz, Windows XP found.
3:36:49 PM : Starting Victoria 4.1, CPU frequency: 2128.18 MHz, Windows XP found.
3:36:49 PM : Select SECONDARY port: base=170h, alternative=376h
3:37:42 PM : Waiting of readiness... Drive is ready
3:37:42 PM : Get passport... OK
3:37:42 PM : Model: IC35L080AVVA07-0; Firmware: VA4OA52A; SN: VNC402A4DL303G; Capacity: 160836480 LBAs
3:38:14 PM : Waiting of readiness... Drive is ready
3:38:14 PM : Get passport... OK
3:38:14 PM : Model: IC35L080AVVA07-0; Firmware: VA4OA52A; SN: VNC402A4DL303G; Capacity: 160836480 LBAs
3:38:16 PM : Waiting of readiness... Drive is ready
3:38:16 PM : Get passport... OK
3:38:16 PM : Model: IC35L080AVVA07-0; Firmware: VA4OA52A; SN: VNC402A4DL303G; Capacity: 160836480 LBAs
3:38:17 PM : Waiting of readiness... Drive is ready
3:38:17 PM : Get passport... OK
3:38:17 PM : Model: IC35L080AVVA07-0; Firmware: VA4OA52A; SN: VNC402A4DL303G; Capacity: 160836480 LBAs
3:38:18 PM : Waiting of readiness... Drive is ready
3:38:18 PM : Get passport... OK
3:38:18 PM : Model: IC35L080AVVA07-0; Firmware: VA4OA52A; SN: VNC402A4DL303G; Capacity: 160836480 LBAs
3:38:19 PM : Waiting of readiness... Drive is ready
3:38:19 PM : Get passport... OK
3:38:19 PM : Model: IC35L080AVVA07-0; Firmware: VA4OA52A; SN: VNC402A4DL303G; Capacity: 160836480 LBAs
3:38:20 PM : Waiting of readiness... Drive is ready
3:38:20 PM : Get passport... OK
3:38:20 PM : Model: IC35L080AVVA07-0; Firmware: VA4OA52A; SN: VNC402A4DL303G; Capacity: 160836480 LBAs
3:38:21 PM : Waiting of readiness... Drive is ready
3:38:21 PM : Get passport... OK
3:38:21 PM : Model: IC35L080AVVA07-0; Firmware: VA4OA52A; SN: VNC402A4DL303G; Capacity: 160836480 LBAs
3:38:22 PM : Waiting of readiness... Drive is ready
3:38:22 PM : Get passport... OK
3:38:22 PM : Model: IC35L080AVVA07-0; Firmware: VA4OA52A; SN: VNC402A4DL303G; Capacity: 160836480 LBAs
3:38:40 PM : Waiting of readiness... Drive is ready
3:38:40 PM : Get passport... OK
3:38:40 PM : Model: IC35L080AVVA07-0; Firmware: VA4OA52A; SN: VNC402A4DL303G; Capacity: 160836480 LBAs
3:39:20 PM : Waiting of readiness... Drive is ready
3:39:20 PM : Get passport... OK
3:39:20 PM : Model: IC35L080AVVA07-0; Firmware: VA4OA52A; SN: VNC402A4DL303G; Capacity: 160836480 LBAs
3:39:21 PM : Waiting of readiness... Drive is ready
3:39:21 PM : Get passport... OK
3:39:21 PM : Model: IC35L080AVVA07-0; Firmware: VA4OA52A; SN: VNC402A4DL303G; Capacity: 160836480 LBAs
3:39:22 PM : Waiting of readiness... Drive is ready
3:39:22 PM : Get passport... OK
3:39:22 PM : Model: IC35L080AVVA07-0; Firmware: VA4OA52A; SN: VNC402A4DL303G; Capacity: 160836480 LBAs
3:39:54 PM : Waiting of readiness... Drive is ready
3:39:54 PM : Get passport... OK
3:39:54 PM : Model: IC35L080AVVA07-0; Firmware: VA4OA52A; SN: VNC402A4DL303G; Capacity: 160836480 LBAs
3:39:55 PM : Waiting of readiness... Drive is ready
3:39:55 PM : Get passport... OK
3:39:55 PM : Model: IC35L080AVVA07-0; Firmware: VA4OA52A; SN: VNC402A4DL303G; Capacity: 160836480 LBAs
3:39:58 PM : Waiting of readiness... Drive is ready
3:39:58 PM : Get passport... OK
3:39:58 PM : Model: IC35L080AVVA07-0; Firmware: VA4OA52A; SN: VNC402A4DL303G; Capacity: 160836480 LBAs
3:40:42 PM : PCI Bus Scan...
3:40:42 PM : VIA/ID 0591*, BUS: 0/DEV: 15/FUN: 0 M
3:40:43 PM : VIA/VT82C571 IDE, BUS: 0/DEV: 15/FUN: 1
3:40:43 PM : 197B*/ID 2363*, BUS: 3/DEV: 0/FUN: 0
3:40:52 PM : Waiting of readiness... Drive not ready!
3:40:52 PM : Get drive passport: Drive error!
3:40:57 PM : PCI Bus Scan...
3:40:57 PM : VIA/ID 0591*, BUS: 0/DEV: 15/FUN: 0 M
3:40:57 PM : VIA/VT82C571 IDE, BUS: 0/DEV: 15/FUN: 1
3:40:57 PM : 197B*/ID 2363*, BUS: 3/DEV: 0/FUN: 0
3:40:58 PM : Waiting of readiness...
3:40:58 PM : Get drive passport: Drive error!
3:41:02 PM : PCI Bus Scan...
3:41:02 PM : VIA/ID 0591*, BUS: 0/DEV: 15/FUN: 0 M
3:41:02 PM : VIA/VT82C571 IDE, BUS: 0/DEV: 15/FUN: 1
3:41:02 PM : 197B*/ID 2363*, BUS: 3/DEV: 0/FUN: 0
3:44:27 PM : Waiting of readiness... Drive not ready!
3:44:27 PM : Get drive passport: Drive error!
3:44:35 PM : PCI Bus Scan...
3:44:35 PM : VIA/ID 0327*, BUS: 0/DEV: 0/FUN: 0 M
3:44:35 PM : VIA/ID 1327*, BUS: 0/DEV: 0/FUN: 1
3:44:35 PM : VIA/ID 2327*, BUS: 0/DEV: 0/FUN: 2
3:44:35 PM : VIA/ID 3327*, BUS: 0/DEV: 0/FUN: 3
3:44:35 PM : VIA/ID 4327*, BUS: 0/DEV: 0/FUN: 4
3:44:35 PM : VIA/ID 5327*, BUS: 0/DEV: 0/FUN: 5 M
3:44:35 PM : VIA/ID 6327*, BUS: 0/DEV: 0/FUN: 6 M
3:44:35 PM : VIA/ID 7327*, BUS: 0/DEV: 0/FUN: 7
3:44:35 PM : VIA/ID B198*, BUS: 0/DEV: 1/FUN: 0
3:44:35 PM : VIA/ID A327*, BUS: 0/DEV: 2/FUN: 0
3:44:35 PM : VIA/ID C327*, BUS: 0/DEV: 3/FUN: 0 M
3:44:35 PM : VIA/ID 0591*, BUS: 0/DEV: 15/FUN: 0 M
3:44:35 PM : VIA/VT82C571 IDE, BUS: 0/DEV: 15/FUN: 1
3:44:35 PM : VIA/ID 3038*, BUS: 0/DEV: 16/FUN: 0 M
3:44:35 PM : VIA/ID 3038*, BUS: 0/DEV: 16/FUN: 1 M
3:44:35 PM : VIA/ID 3038*, BUS: 0/DEV: 16/FUN: 2 M
3:44:35 PM : VIA/ID 3038*, BUS: 0/DEV: 16/FUN: 3 M
3:44:35 PM : VIA/ID 3104*, BUS: 0/DEV: 16/FUN: 4 M
3:44:35 PM : VIA/ID 3337*, BUS: 0/DEV: 17/FUN: 0 M
3:44:35 PM : VIA/ID 287E*, BUS: 0/DEV: 17/FUN: 7
3:44:35 PM : VIA/ID 337B*, BUS: 0/DEV: 19/FUN: 0 M
3:44:35 PM : VIA/ID 337A*, BUS: 0/DEV: 19/FUN: 1
3:44:35 PM : Nvidia/ID 0391*, BUS: 2/DEV: 0/FUN: 0
3:44:35 PM : 197B*/ID 2363*, BUS: 3/DEV: 0/FUN: 0
3:44:35 PM : Realtek/ID 8167*, BUS: 4/DEV: 7/FUN: 0
3:44:35 PM : Realtek/ID 8167*, BUS: 4/DEV: 7/FUN: 1
3:44:35 PM : Realtek/ID 8167*, BUS: 4/DEV: 7/FUN: 2
3:44:35 PM : Realtek/ID 8167*, BUS: 4/DEV: 7/FUN: 3
3:44:35 PM : Realtek/ID 8167*, BUS: 4/DEV: 7/FUN: 4
3:44:35 PM : Realtek/ID 8167*, BUS: 4/DEV: 7/FUN: 5
3:44:35 PM : Realtek/ID 8167*, BUS: 4/DEV: 7/FUN: 6
3:44:35 PM : Realtek/ID 8167*, BUS: 4/DEV: 7/FUN: 7
3:47:50 PM : Waiting of readiness...
3:47:50 PM : Get drive passport: Drive error!
3:48:01 PM : PCI Bus Scan...
3:48:01 PM : VIA/ID 0591*, BUS: 0/DEV: 15/FUN: 0 M
3:48:01 PM : VIA/VT82C571 IDE, BUS: 0/DEV: 15/FUN: 1
3:48:01 PM : 197B*/ID 2363*, BUS: 3/DEV: 0/FUN: 0
3:48:13 PM : Waiting of readiness... Drive is ready
3:48:13 PM : Get passport... OK
3:48:13 PM : Model: WDC WD400BD-60LTA0; Firmware: 07.01D07; SN: WD-WMAMF1752302; Capacity: 78165360 LBAs
3:48:20 PM : PCI Bus Scan...
3:48:20 PM : VIA/ID 0591*, BUS: 0/DEV: 15/FUN: 0 M
3:48:20 PM : VIA/VT82C571 IDE, BUS: 0/DEV: 15/FUN: 1
3:48:20 PM : 197B*/ID 2363*, BUS: 3/DEV: 0/FUN: 0
3:48:22 PM : Waiting of readiness... Drive is ready
3:48:22 PM : Get passport... OK
3:48:22 PM : 48bit access enabled
3:48:22 PM : Model: Maxtor 7L300S0; Firmware: BANC1G10; SN: L603AYRG; Capacity: 586114704 LBAs
3:48:35 PM : Waiting of readiness... Drive is ready
3:48:35 PM : Get passport... OK
3:48:35 PM : Recallibration...
3:48:35 PM : Recallibration... OK
3:48:35 PM : Starting surface scan, LBA=0..586114704, sequential access, timeout 10000ms
3:54:40 PM : Block 45788928 Timeout
4:06:02 PM : Warning! Block start at 130992384 = 201 ms
4:15:30 PM : Warning! Block start at 199163648 = 541 ms
4:40:33 PM : Block 364901120 Error: ABRT
4:46:41 PM : Block 400961792 Timeout
4:50:47 PM : Block 424122112 Timeout
4:51:04 PM : Command interrupted by user!
4:51:04 PM : ***** Scan results: Warnings - 2, errors - 4 *****
4:51:16 PM : Waiting of readiness... Drive is ready
4:51:16 PM : Get passport... OK
4:51:16 PM : Recallibration...
4:51:16 PM : Recallibration... OK
4:51:17 PM : Starting surface scan, LBA=0..586114704, sequential access, timeout 10000ms
4:52:46 PM : Block 10205952 Timeout
4:53:42 PM : Block 16125952 Timeout
4:54:30 PM : Warning! Block start at 22206976 = 521 ms
4:54:42 PM : Warning! Block start at 23764224 = 206 ms
4:55:29 PM : Block 29830400 Error: ABRT
5:06:02 PM : Warning! Block start at 109666816 = 193 ms
5:27:32 PM : Block 262605568 Error: ABRT
5:31:30 PM : Warning! Block start at 288888320 = 579 ms
6:06:02 PM : Warning! Block start at 493790720 = 179 ms
6:08:06 PM : Block 504041216 Error: UNCR
6:08:08 PM : Block 504067072 Error: UNCR
6:08:10 PM : Block 504079616 Error: UNCR
6:08:20 PM : Block 504088832 Timeout
6:08:22 PM : Warning! Block start at 504089088 = 1487 ms
6:08:23 PM : Block 504095488 Error: UNCR
6:08:26 PM : Block 504117248 Error: UNCR
6:08:29 PM : Block 504127232 Error: UNCR
6:08:32 PM : Block 504133888 Error: UNCR
6:08:35 PM : Block 504136192 Error: UNCR
6:08:39 PM : Warning! Block start at 504172544 = 2818 ms
6:08:45 PM : Block 504365056 Error: UNCR
6:08:48 PM : Block 504374784 Error: UNCR
6:08:50 PM : Block 504384000 Error: UNCR
6:08:51 PM : Block 504393728 Error: UNCR
6:08:54 PM : Block 504402688 Error: UNCR
6:08:57 PM : Block 504419328 Error: UNCR
6:09:00 PM : Block 504422400 Error: UNCR
6:09:02 PM : Warning! Block start at 504429056 = 1429 ms
6:10:32 PM : Warning! Block start at 511856128 = 779 ms
6:10:47 PM : Warning! Block start at 513044480 = 542 ms
6:16:16 PM : Warning! Block start at 539347968 = 153 ms
6:16:19 PM : Block 539359232 Error: UNCR
6:16:22 PM : Block 539374848 Error: UNCR
6:16:23 PM : Block 539377664 Error: UNCR
6:16:26 PM : Block 539384064 Error: UNCR
6:16:30 PM : Block 539401728 Error: UNCR
6:16:33 PM : Block 539412736 Error: UNCR
6:16:46 PM : Warning! Block start at 539635712 = 9875 ms
6:16:48 PM : Warning! Block start at 539653888 = 1011 ms
6:16:49 PM : Warning! Block start at 539689216 = 160 ms
6:16:49 PM : Warning! Block start at 539707648 = 128 ms
6:17:11 PM : Block 540295424 Timeout
6:17:22 PM : Block 540331264 Timeout
6:17:32 PM : Block 540348928 Timeout
6:17:42 PM : Warning! Block start at 540349184 = 9721 ms
6:17:53 PM : Block 540366592 Timeout
6:18:00 PM : Warning! Block start at 540366848 = 7104 ms
6:18:14 PM : Warning! Block start at 540385024 = 9220 ms
6:18:18 PM : Warning! Block start at 540385280 = 7128 ms
6:18:20 PM : Warning! Block start at 540385536 = 1884 ms
6:18:30 PM : Warning! Block start at 540402432 = 768 ms
6:18:30 PM : Warning! Block start at 540402688 = 1159 ms
6:18:30 PM : Warning! Block start at 540403456 = 279 ms
6:18:40 PM : Warning! Block start at 540420096 = 6101 ms
6:18:40 PM : Warning! Block start at 540420352 = 2415 ms
6:18:51 PM : Warning! Block start at 540437760 = 5647 ms
6:18:51 PM : Warning! Block start at 540438016 = 1055 ms
6:18:52 PM : Warning! Block start at 540456448 = 271 ms
6:18:55 PM : Block 540471808 Error: UNCR
6:18:58 PM : Block 540480256 Error: UNCR
6:19:01 PM : Warning! Block start at 540482816 = 2845 ms
6:19:04 PM : Block 540489472 Error: UNCR
6:19:07 PM : Block 540498432 Error: UNCR
6:19:10 PM : Block 540500480 Error: UNCR
6:19:13 PM : Block 540506880 Error: UNCR
6:19:14 PM : Warning! Block start at 540560640 = 243 ms
6:19:15 PM : Warning! Block start at 540606720 = 224 ms
6:19:19 PM : Warning! Block start at 540820480 = 833 ms
6:19:40 PM : Block 542265856 Error: UNCR
6:19:43 PM : Block 542272256 Error: UNCR
6:19:46 PM : Warning! Block start at 542275072 = 2819 ms
6:19:49 PM : Block 542281472 Error: UNCR
6:19:52 PM : Block 542283520 Error: UNCR
6:19:55 PM : Block 542292736 Error: UNCR
6:19:58 PM : Block 542299136 Error: UNCR
6:20:01 PM : Block 542308352 Error: UNCR
6:20:04 PM : Block 542310144 Error: UNCR
6:20:14 PM : Block 542316800 Timeout
6:20:20 PM : Block 542459904 Error: UNCR
6:20:27 PM : Block 542693888 Error: UNCR
6:20:34 PM : Block 542869504 Error: UNCR
6:20:35 PM : Block 542872064 Error: UNCR
6:20:42 PM : Block 543074560 Error: UNCR
6:20:45 PM : Block 543092992 Error: UNCR
6:20:48 PM : Block 543095040 Error: UNCR
6:20:51 PM : Warning! Block start at 543101440 = 2779 ms
6:20:54 PM : Block 543104256 Error: UNCR
6:20:57 PM : Block 543110656 Error: UNCR
6:21:00 PM : Block 543119104 Error: UNCR
6:21:00 PM : Warning! Block start at 543139328 = 136 ms
6:21:47 PM : Warning! Block start at 546759936 = 136 ms
6:21:47 PM : Warning! Block start at 546761728 = 184 ms
6:21:50 PM : Block 546770944 Error: UNCR
6:21:52 PM : Warning! Block start at 546842112 = 127 ms
6:21:55 PM : Block 546848512 Error: UNCR
6:21:58 PM : Block 546884608 Error: UNCR
6:21:59 PM : Warning! Block start at 546886656 = 168 ms
6:22:02 PM : Warning! Block start at 546913280 = 3260 ms
6:22:26 PM : Warning! Block start at 548774912 = 145 ms
6:22:26 PM : Warning! Block start at 548776960 = 177 ms
6:22:27 PM : Warning! Block start at 548809984 = 120 ms
6:22:29 PM : Warning! Block start at 548819200 = 2326 ms
6:22:30 PM : Warning! Block start at 548854528 = 120 ms
6:22:32 PM : Warning! Block start at 548960768 = 246 ms
6:22:35 PM : Block 548988416 Error: UNCR
6:22:36 PM : Warning! Block start at 548997632 = 151 ms
6:22:44 PM : Block 549486336 Error: UNCR
6:22:45 PM : Block 549491712 Error: UNCR
6:22:48 PM : Block 549495552 Error: UNCR
6:22:51 PM : Block 549500672 Error: UNCR
6:22:54 PM : Block 549504000 Error: UNCR
6:23:04 PM : Block 549509120 Timeout
6:23:05 PM : Warning! Block start at 549509376 = 1457 ms
6:23:08 PM : Block 549522432 Error: UNCR
6:23:11 PM : Block 549527552 Error: UNCR
6:23:14 PM : Block 549530880 Error: UNCR
6:23:17 PM : Block 549545216 Error: UNCR
6:23:29 PM : Block 549611264 Timeout
6:23:39 PM : Block 549634048 Timeout
6:23:41 PM : Block 549647104 Error: UNCR
6:23:44 PM : Block 549709312 Error: UNCR
6:23:47 PM : Block 549732096 Error: UNCR
6:23:50 PM : Block 549767936 Error: UNCR
6:23:54 PM : Block 549807104 Error: UNCR
6:23:58 PM : Block 549843200 Error: UNCR
6:24:01 PM : Block 549851648 Error: UNCR
6:24:02 PM : Warning! Block start at 549860864 = 1411 ms
6:24:05 PM : Block 549869824 Error: UNCR
6:24:08 PM : Block 549878272 Error: UNCR
6:24:11 PM : Block 549883648 Error: UNCR
6:24:14 PM : Block 549887488 Error: UNCR
6:24:17 PM : Block 549892864 Error: UNCR
6:24:20 PM : Block 549896704 Error: UNCR
6:24:52 PM : Warning! Block start at 552228608 = 162 ms
6:24:52 PM : Warning! Block start at 552239104 = 161 ms
6:24:56 PM : Block 552269824 Error: UNCR
6:24:59 PM : Block 552277760 Error: UNCR
6:25:02 PM : Block 552280320 Error: UNCR
6:25:05 PM : Block 552286208 Error: UNCR
6:25:15 PM : Block 552288256 Timeout
6:25:16 PM : Block 552296704 Error: UNCR
6:25:19 PM : Warning! Block start at 552305152 = 2452 ms
6:25:20 PM : Block 552311040 Error: UNCR
6:25:23 PM : Block 552319744 Error: UNCR
6:25:26 PM : Block 552321536 Error: UNCR
6:25:29 PM : Block 552327424 Error: UNCR
6:25:32 PM : Block 552330240 Error: UNCR
6:25:42 PM : Block 552336128 Timeout
6:25:44 PM : Block 552337920 Error: UNCR
6:25:47 PM : Block 552344576 Error: UNCR
6:25:50 PM : Block 552355072 Error: UNCR
6:25:53 PM : Block 552360960 Error: UNCR
6:25:56 PM : Block 552363008 Error: UNCR
6:25:59 PM : Block 552371456 Error: UNCR
6:26:02 PM : Block 552377344 Error: UNCR
6:26:05 PM : Block 552393728 Error: UNCR
6:26:08 PM : Block 552396288 Error: UNCR
6:26:11 PM : Warning! Block start at 552410880 = 1528 ms
6:26:12 PM : Warning! Block start at 552421376 = 120 ms
6:26:28 PM : Block 553420800 Error: UNCR
6:26:31 PM : Block 553425664 Error: UNCR
6:26:34 PM : Block 553429248 Error: UNCR
6:26:37 PM : Block 553434112 Error: UNCR
6:26:39 PM : Warning! Block start at 553437952 = 1402 ms
6:26:40 PM : Block 553442816 Error: UNCR
6:26:50 PM : Block 553445632 Timeout
6:26:55 PM : Warning! Block start at 553445888 = 4824 ms
6:26:58 PM : Block 553459200 Error: UNCR
6:27:34 PM : Block 554697984 Timeout
6:27:35 PM : Warning! Block start at 554698240 = 1513 ms
6:27:45 PM : Block 554702848 Timeout
6:27:56 PM : Block 554705920 Timeout
6:27:57 PM : Block 554710784 Error: UNCR
6:28:07 PM : Block 554714368 Timeout
6:28:10 PM : Warning! Block start at 554719232 = 1884 ms
6:28:13 PM : Block 554722816 Error: UNCR
6:28:23 PM : Block 554727936 Timeout
6:28:25 PM : Block 554730752 Error: UNCR
6:28:35 PM : Block 554735616 Timeout
6:28:38 PM : Block 554739200 Error: UNCR
6:28:41 PM : Block 554744320 Error: UNCR
6:28:51 PM : Block 554747904 Timeout
6:28:53 PM : Warning! Block start at 554748160 = 1480 ms
6:28:53 PM : Warning! Block start at 554755584 = 253 ms
6:30:20 PM : Block 561012224 Error: UNCR
6:30:23 PM : Block 561015808 Error: UNCR
6:30:26 PM : Block 561020672 Error: UNCR
6:30:29 PM : Block 561028608 Error: UNCR
6:30:32 PM : Block 561032192 Error: UNCR
6:30:35 PM : Block 561040640 Error: UNCR
6:30:41 PM : Warning! Block start at 561261312 = 261 ms
6:30:41 PM : Warning! Block start at 561269248 = 219 ms
6:30:51 PM : Block 561272832 Timeout
6:30:58 PM : Warning! Block start at 561273088 = 7314 ms
6:31:09 PM : Block 561286400 Timeout
6:31:16 PM : Warning! Block start at 561286656 = 7278 ms
6:31:26 PM : Block 561289216 Timeout
6:31:26 PM : Warning! Block start at 561289472 = 283 ms
6:31:36 PM : Block 561294080 Timeout
6:31:36 PM : Warning! Block start at 561294336 = 156 ms
6:31:47 PM : Block 561310464 Timeout
6:31:54 PM : Warning! Block start at 561310720 = 2530 ms
6:31:54 PM : Warning! Block start at 561310976 = 887 ms
6:31:58 PM : Warning! Block start at 561314048 = 3568 ms
6:32:03 PM : Warning! Block start at 561314304 = 4989 ms
6:32:05 PM : Warning! Block start at 561314560 = 1989 ms
6:32:06 PM : Warning! Block start at 561314816 = 621 ms
6:32:14 PM : Warning! Block start at 561322752 = 7597 ms
6:32:24 PM : Block 561327616 Timeout
6:32:34 PM : Block 561335552 Error: AMNF
6:32:44 PM : Block 561339136 Timeout
6:32:54 PM : Warning! Block start at 561344000 = 9220 ms
6:33:04 PM : Block 561347584 Timeout
6:33:09 PM : Warning! Block start at 561347840 = 4847 ms
6:33:17 PM : Warning! Block start at 561352448 = 7511 ms
6:33:27 PM : Block 561355520 Timeout
6:33:32 PM : Warning! Block start at 561355776 = 5038 ms
6:33:42 PM : Block 561360384 Timeout
6:33:42 PM : Warning! Block start at 561360640 = 173 ms
6:33:50 PM : Warning! Block start at 561363968 = 3282 ms
6:33:50 PM : Warning! Block start at 561364224 = 3355 ms
6:34:00 PM : Block 561368832 Timeout
6:34:10 PM : Block 561385216 Timeout
6:34:11 PM : Warning! Block start at 561385472 = 299 ms
6:34:18 PM : Block 561388800 Error: UNCR
6:34:28 PM : Block 561393920 Timeout
6:34:34 PM : Warning! Block start at 561394176 = 1470 ms
6:34:36 PM : Warning! Block start at 561394432 = 1850 ms
6:34:43 PM : Warning! Block start at 561397504 = 7753 ms
6:34:46 PM : Warning! Block start at 561397760 = 2411 ms
6:34:54 PM : Warning! Block start at 561405440 = 413 ms
6:34:54 PM : Warning! Block start at 561413888 = 190 ms
6:35:04 PM : Warning! Block start at 561414144 = 5626 ms
6:35:04 PM : Warning! Block start at 561414400 = 271 ms
6:35:12 PM : Warning! Block start at 561422336 = 5830 ms
6:35:19 PM : Warning! Block start at 561430272 = 5829 ms
6:35:20 PM : Warning! Block start at 561430784 = 642 ms
6:35:28 PM : Warning! Block start at 561443584 = 5088 ms
6:35:28 PM : Warning! Block start at 561444096 = 599 ms
6:35:37 PM : Block 561476352 Error: UNCR
6:35:49 PM : Block 561579776 Timeout
6:35:56 PM : Warning! Block start at 561580032 = 7287 ms
6:36:04 PM : Warning! Block start at 561601024 = 7460 ms
6:36:14 PM : Block 561609472 Timeout
6:36:21 PM : Warning! Block start at 561609728 = 7296 ms
6:36:29 PM : Block 561617408 Error: AMNF
6:36:34 PM : Warning! Block start at 561634560 = 590 ms
6:36:39 PM : Warning! Block start at 561634816 = 5295 ms
6:36:43 PM : Warning! Block start at 561637376 = 4067 ms
6:36:46 PM : Warning! Block start at 561637632 = 3142 ms
6:36:57 PM : Warning! Block start at 561650944 = 566 ms
6:36:57 PM : Warning! Block start at 561651200 = 2097 ms
6:37:02 PM : Warning! Block start at 561654528 = 940 ms
6:37:04 PM : Warning! Block start at 561654784 = 1608 ms
6:37:12 PM : Warning! Block start at 561659392 = 2292 ms
6:37:12 PM : Warning! Block start at 561662464 = 164 ms
6:37:19 PM : Warning! Block start at 561662720 = 5675 ms
6:37:19 PM : Warning! Block start at 561662976 = 586 ms
6:37:27 PM : Warning! Block start at 561675776 = 5682 ms
6:37:38 PM : Warning! Block start at 561679360 = 5937 ms
6:37:38 PM : Warning! Block start at 561679616 = 2556 ms
6:37:38 PM : Warning! Block start at 561679872 = 232 ms
6:37:39 PM : Warning! Block start at 561680128 = 534 ms
6:37:39 PM : Warning! Block start at 561683968 = 153 ms
6:37:49 PM : Block 561684224 Timeout
6:37:57 PM : Block 561687296 Error: UNCR
6:38:07 PM : Block 561692160 Timeout
6:38:15 PM : Warning! Block start at 561692416 = 7521 ms
6:38:22 PM : Warning! Block start at 561700608 = 4400 ms
6:38:22 PM : Warning! Block start at 561700864 = 1845 ms
6:38:32 PM : Block 561703680 Timeout
6:38:42 PM : Block 561712128 Timeout
6:38:53 PM : Block 561716992 Timeout
6:38:58 PM : Warning! Block start at 561717248 = 4864 ms
6:39:05 PM : Warning! Block start at 561728512 = 4393 ms
6:39:05 PM : Warning! Block start at 561728768 = 2094 ms
6:39:13 PM : Block 561733376 Error: AMNF
6:39:20 PM : Warning! Block start at 561742080 = 7275 ms
6:39:21 PM : Warning! Block start at 561762048 = 160 ms
6:39:32 PM : Block 562164992 Error: UNCR
6:39:35 PM : Block 562173440 Error: UNCR
6:39:38 PM : Warning! Block start at 562176512 = 2802 ms
6:39:41 PM : Block 562181376 Error: UNCR
6:39:44 PM : Block 562184960 Error: UNCR
6:39:47 PM : Block 562189824 Error: UNCR
6:39:50 PM : Block 562193408 Error: UNCR
6:40:00 PM : Block 562198272 Timeout
6:40:02 PM : Block 562201344 Error: UNCR
6:40:24 PM : Block 563549696 Error: UNCR
6:40:27 PM : Block 563552512 Error: UNCR
6:40:28 PM : Block 563557376 Error: UNCR
6:40:31 PM : Block 563561216 Error: UNCR
6:40:34 PM : Block 563566080 Error: UNCR
6:41:03 PM : Block 564486656 Timeout
6:41:13 PM : Block 564489728 Timeout
6:41:14 PM : Block 564494592 Error: UNCR
6:41:24 PM : Block 564498176 Timeout
6:41:26 PM : Block 564503040 Error: UNCR
6:41:29 PM : Block 564506624 Error: UNCR
6:42:05 PM : Block 566902528 Error: UNCR
6:42:08 PM : Block 566907392 Error: UNCR
6:42:11 PM : Block 566911232 Error: UNCR
6:42:14 PM : Block 566916096 Error: UNCR
6:42:17 PM : Block 566919680 Error: UNCR
6:42:20 PM : Block 566932480 Error: UNCR
6:42:41 PM : Block 567828224 Error: UNCR
6:42:45 PM : Block 567839744 Error: UNCR
6:42:48 PM : Warning! Block start at 567844608 = 2811 ms
6:42:50 PM : Block 567848192 Error: UNCR
6:42:53 PM : Block 567853056 Error: UNCR
6:42:56 PM : Block 567856640 Error: UNCR
6:42:59 PM : Block 567861504 Error: UNCR
6:43:02 PM : Block 567864576 Error: UNCR
6:43:03 PM : Warning! Block start at 567869440 = 445 ms
6:43:42 PM : Block 570509568 Error: UNCR
6:43:44 PM : Block 570514432 Error: UNCR
6:43:47 PM : Warning! Block start at 570518272 = 2853 ms
6:43:50 PM : Block 570523136 Error: UNCR
6:43:53 PM : Block 570526720 Error: UNCR
6:43:55 PM : Block 570531584 Error: UNCR
6:43:58 PM : Block 570534656 Error: UNCR
6:44:09 PM : Block 570539520 Timeout
6:44:11 PM : Block 570580736 Error: UNCR
6:44:14 PM : Block 570584320 Error: UNCR
6:44:22 PM : Warning! Block start at 570597888 = 3098 ms
6:44:26 PM : Warning! Block start at 570598144 = 7411 ms
6:44:26 PM : Warning! Block start at 570600704 = 135 ms
6:44:27 PM : Block 570600960 Error: UNCR
6:44:29 PM : Warning! Block start at 570614272 = 1403 ms
6:44:32 PM : Warning! Block start at 570617856 = 1933 ms
6:44:34 PM : Warning! Block start at 570630656 = 1483 ms
6:44:34 PM : Warning! Block start at 570630912 = 151 ms
6:44:37 PM : Block 570634240 Error: UNCR
6:44:40 PM : Block 570639104 Error: UNCR
6:44:43 PM : Warning! Block start at 570642688 = 2804 ms
6:44:45 PM : Block 570647552 Error: UNCR
6:44:48 PM : Block 570650624 Error: UNCR
6:44:51 PM : Block 570655488 Error: UNCR
6:44:54 PM : Block 570659072 Error: UNCR
6:44:57 PM : Block 570672640 Error: UNCR
6:45:00 PM : Block 570675456 Error: UNCR
6:45:03 PM : Block 570689024 Error: UNCR
6:45:06 PM : Block 570692608 Error: UNCR
6:45:10 PM : Block 570705408 Error: UNCR
6:45:13 PM : Block 570708992 Error: UNCR
6:45:16 PM : Warning! Block start at 570722304 = 1955 ms
6:45:16 PM : Warning! Block start at 570722560 = 241 ms
6:45:17 PM : Warning! Block start at 570725376 = 1475 ms
6:45:28 PM : Block 570733824 Timeout
6:45:29 PM : Warning! Block start at 570734080 = 1484 ms
6:45:32 PM : Block 570741760 Error: UNCR
6:45:35 PM : Block 570750208 Error: UNCR
6:45:38 PM : Block 570763776 Error: UNCR
6:45:41 PM : Block 570766592 Error: UNCR
6:45:52 PM : Block 570780160 Timeout
6:45:53 PM : Warning! Block start at 570780416 = 1455 ms
6:45:55 PM : Block 570783744 Error: UNCR
6:46:05 PM : Block 570796544 Timeout
6:46:05 PM : Warning! Block start at 570800128 = 397 ms
6:46:06 PM : Block 570800384 Error: UNCR
6:46:09 PM : Warning! Block start at 570808576 = 2829 ms
6:46:11 PM : Warning! Block start at 570816512 = 1782 ms
6:46:12 PM : Block 570816768 Error: UNCR
6:46:15 PM : Warning! Block start at 570824960 = 1750 ms
6:46:16 PM : Warning! Block start at 570825216 = 645 ms
6:46:18 PM : Block 570838528 Error: UNCR
6:46:19 PM : Block 570841344 Error: UNCR
6:46:23 PM : Warning! Block start at 570854912 = 2949 ms
6:46:25 PM : Block 570857984 Error: UNCR
6:46:27 PM : Block 570871296 Error: UNCR
6:46:30 PM : Block 570874880 Error: UNCR
6:46:40 PM : Block 570887680 Timeout
6:46:42 PM : Block 570891264 Error: UNCR
6:46:45 PM : Block 570899712 Error: UNCR
6:46:48 PM : Block 570907648 Error: UNCR
6:46:51 PM : Block 570916352 Error: UNCR
6:46:54 PM : Block 570929664 Error: UNCR
6:46:57 PM : Block 570932736 Error: UNCR
6:47:00 PM : Block 570946048 Error: UNCR
6:47:03 PM : Warning! Block start at 570949632 = 2091 ms
6:47:06 PM : Block 570962432 Error: UNCR
6:47:09 PM : Block 570966016 Error: UNCR
6:47:12 PM : Block 570974464 Error: UNCR
6:47:15 PM : Block 570978816 Error: UNCR
6:47:18 PM : Block 570982400 Error: UNCR
6:47:21 PM : Block 570991104 Error: UNCR
6:47:24 PM : Warning! Block start at 570998784 = 2830 ms
6:47:27 PM : Block 571007488 Error: UNCR
6:47:30 PM : Block 571020800 Error: UNCR
6:47:33 PM : Block 571023872 Error: UNCR
6:47:44 PM : Block 571037184 Timeout
6:47:45 PM : Block 571040768 Error: UNCR
6:47:48 PM : Block 571053568 Error: UNCR
6:47:58 PM : Warning! Block start at 571057152 = 6087 ms
6:47:58 PM : Warning! Block start at 571057408 = 2411 ms
6:47:59 PM : Warning! Block start at 571057664 = 209 ms
6:47:59 PM : Warning! Block start at 571057920 = 536 ms
6:48:02 PM : Block 571065856 Error: UNCR
6:48:05 PM : Block 571073536 Error: UNCR
6:48:08 PM : Block 571082240 Error: UNCR
6:48:09 PM : Warning! Block start at 571090176 = 188 ms
6:48:19 PM : Block 571095552 Timeout
6:48:20 PM : Block 571098624 Error: UNCR
6:48:23 PM : Block 571111936 Error: UNCR
6:48:26 PM : Block 571115008 Error: UNCR
6:48:30 PM : Block 571128320 Error: UNCR
6:48:32 PM : Block 571131904 Error: UNCR
6:48:36 PM : Block 571144704 Error: UNCR
6:48:39 PM : Block 571148288 Error: UNCR
6:48:42 PM : Block 571156992 Error: UNCR
6:48:45 PM : Block 571164672 Error: UNCR
6:48:55 PM : Block 571173376 Timeout
6:48:56 PM : Warning! Block start at 571173632 = 1512 ms
6:48:57 PM : Warning! Block start at 571186688 = 507 ms
6:48:59 PM : Block 571186944 Error: UNCR
6:49:02 PM : Warning! Block start at 571189760 = 2589 ms
6:49:06 PM : Block 571203072 Error: UNCR
6:49:08 PM : Block 571206656 Error: UNCR
6:49:10 PM : Warning! Block start at 571219456 = 904 ms
6:49:11 PM : Warning! Block start at 571219712 = 629 ms
6:49:12 PM : Warning! Block start at 571223040 = 1469 ms
6:49:15 PM : Block 571231744 Error: UNCR
6:49:18 PM : Block 571239424 Error: UNCR
6:49:29 PM : Block 571248128 Timeout
6:49:32 PM : Block 571255808 Error: UNCR
6:49:35 PM : Block 571260672 Error: UNCR
6:49:38 PM : Block 571264512 Error: UNCR
6:49:41 PM : Block 571277824 Error: UNCR
6:49:44 PM : Block 571280896 Error: UNCR
6:49:47 PM : Block 571294208 Error: UNCR
6:49:50 PM : Block 571297792 Error: UNCR
6:49:53 PM : Warning! Block start at 571310592 = 2107 ms
6:49:56 PM : Block 571314176 Error: UNCR
6:49:59 PM : Warning! Block start at 571330560 = 2303 ms
6:50:02 PM : Block 571344128 Error: UNCR
6:50:05 PM : Block 571347712 Error: UNCR
6:50:07 PM : Block 571352576 Error: UNCR
6:50:10 PM : Block 571355648 Error: UNCR
6:50:21 PM : Block 571368960 Timeout
6:50:22 PM : Block 571372544 Error: UNCR
6:50:25 PM : Block 571376896 Error: UNCR
6:50:28 PM : Block 571380480 Error: UNCR
6:50:31 PM : Block 571385344 Error: UNCR
6:50:35 PM : Warning! Block start at 571656704 = 241 ms
6:50:52 PM : Warning! Block start at 572870912 = 168 ms
PostPosted: March 27th, 2007, 2:17
I've been having a difficult time with the documentation for the program. I tried visiting the website but google doesn't want to translate the entire thing. What do the errors mean and how do I use the program to restore the data?
PostPosted: March 27th, 2007, 3:28
u need to enable the advance remap option in the Sequential reading option in order to remove bad sectors in
ur drive and there is a little help if u press F1 in the program it gives u a short help read that .
PostPosted: March 27th, 2007, 4:01
Am I blind? I'm afraid I dont see those options :S
Under the "Advanced" tab I only see the following options:
Cache switch commands
Determine RPM
Add/Remove 55AAh
Partition Viewer
And under the "Setup" tab I only see the following options:
BUSY Timeout
DREQ Timeout
Ready Timeout
Sound
Seek & Surface scan options
Common presets
Log settings
Where is these "advanced remap" and "sequential read" you speak of? Sorry I'm sucha n00b :(
EDIT: In the TEST tab I found an area where you can select ONE of four options which was originally set on ignore-- "Ignore, Erase, Remap, Restore" - is this what you are ref to?
PostPosted: March 27th, 2007, 14:29
detect drive by selecting port using this "p" button then press "F4" there comes a menu in the first option select Sequential reading then in the second option select Advance Remap by using the arrow keys .
PostPosted: March 27th, 2007, 17:11
"F1" does not bring up the help, and "F4" does not bring up more options. Am I using an incorrect version? Are you using 4.1 beta freeware?
Anyway, I tried as best as I could to enable REMAP on the version I'm using and here is the results of the LOG file:
3:22:03 AM : Waiting of readiness... Drive is ready
3:22:03 AM : Get passport... OK
3:22:03 AM : Recallibration...
3:22:03 AM : Recallibration... OK
3:22:04 AM : Starting surface scan, LBA=0..586114704, sequential access w. REMAP, tio 1000ms
3:50:35 AM : Warning! Block start at 211800320 = 186 ms
3:54:39 AM : Block 239968256 Error: ABRT
4:38:30 AM : Warning! Block start at 504019456 = 152 ms
4:38:33 AM : LBA 504041447 try REMAR...
4:38:33 AM : LBA 504041447 try REMAP... complete
4:38:34 AM : Block 504041448 Timeout
4:38:40 AM : LBA 504067099 try REMAR...
4:38:40 AM : LBA 504067099 try REMAP... complete
4:38:41 AM : Block 504067100 Timeout
4:38:45 AM : LBA 504079867 try REMAR...
4:38:45 AM : LBA 504079867 try REMAP... complete
4:38:46 AM : Block 504079868 Timeout
4:38:51 AM : LBA 504088875 try REMAR...
4:38:51 AM : LBA 504088875 try REMAP... complete
4:38:52 AM : Block 504088876 Timeout
4:38:57 AM : LBA 504095715 try REMAR...
4:38:57 AM : LBA 504095715 try REMAP... complete
4:38:58 AM : Block 504095716 Timeout
4:39:02 AM : LBA 504117491 try REMAR...
4:39:02 AM : LBA 504117491 try REMAP... complete
4:39:03 AM : Block 504117492 Timeout
4:39:08 AM : LBA 504127294 try REMAR...
4:39:08 AM : LBA 504127294 try REMAP... complete
4:39:09 AM : Block 504127295 Timeout
4:39:14 AM : LBA 504133995 try REMAR...
4:39:14 AM : LBA 504133995 try REMAP... complete
4:39:16 AM : LBA 504134134 try REMAR...
4:39:16 AM : LBA 504134134 try REMAP... complete
4:39:17 AM : Block 504134135 Timeout
4:39:22 AM : LBA 504136303 try REMAR...
4:39:22 AM : LBA 504136303 try REMAP... complete
4:39:23 AM : Block 504136304 Timeout
4:39:28 AM : LBA 504172552 try REMAR...
4:39:28 AM : LBA 504172552 try REMAP... complete
4:39:29 AM : Block 504172553 Timeout
4:39:37 AM : LBA 504365225 try REMAR...
4:39:37 AM : LBA 504365225 try REMAP... complete
4:39:38 AM : Block 504365226 Timeout
4:39:43 AM : LBA 504375029 try REMAR...
4:39:43 AM : LBA 504375029 try REMAP... complete
4:39:44 AM : Block 504375030 Timeout
4:39:48 AM : LBA 504384037 try REMAR...
4:39:48 AM : LBA 504384037 try REMAP... complete
4:39:49 AM : Block 504384038 Timeout
4:39:54 AM : LBA 504393841 try REMAR...
4:39:54 AM : LBA 504393841 try REMAP... complete
4:39:57 AM : Warning! Block start at 504393842 = 568 ms
4:39:57 AM : Block 504394098 Timeout
4:40:00 AM : LBA 504402849 try REMAR...
4:40:00 AM : LBA 504402849 try REMAP... complete
4:40:01 AM : Block 504402850 Timeout
4:40:06 AM : LBA 504419493 try REMAR...
4:40:06 AM : LBA 504419493 try REMAP... complete
4:40:07 AM : Block 504419494 Timeout
4:40:11 AM : LBA 504422457 try REMAR...
4:40:11 AM : LBA 504422457 try REMAP... complete
4:40:12 AM : Block 504422458 Timeout
4:40:17 AM : LBA 504429297 try REMAR...
4:40:17 AM : LBA 504429297 try REMAP... complete
4:40:18 AM : Block 504429298 Timeout
4:47:31 AM : Warning! Block start at 539347954 = 128 ms
4:47:34 AM : LBA 539359342 try REMAR...
4:47:34 AM : LBA 539359342 try REMAP... complete
4:47:35 AM : Block 539359343 Timeout
4:47:40 AM : LBA 539374964 try REMAR...
4:47:40 AM : LBA 539374964 try REMAP... complete
4:47:41 AM : Block 539374965 Timeout
4:47:46 AM : LBA 539377701 try REMAR...
4:47:46 AM : LBA 539377701 try REMAP... complete
4:47:47 AM : Block 539377702 Timeout
4:47:51 AM : LBA 539384143 try REMAR...
4:47:51 AM : LBA 539384143 try REMAP... complete
4:47:52 AM : Block 539384144 Timeout
4:47:57 AM : LBA 539401758 try REMAR...
4:47:57 AM : LBA 539401758 try REMAP... complete
4:47:58 AM : Block 539401759 Timeout
4:48:03 AM : LBA 539412931 try REMAR...
4:48:03 AM : LBA 539412931 try REMAP... complete
4:48:04 AM : Block 539412932 Timeout
4:48:13 AM : Block 540295364 Timeout
4:48:31 AM : Block 540331460 Timeout
4:49:29 AM : LBA 540349067 try REMAR...
4:49:30 AM : LBA 540349067 try REMAP... complete
4:49:54 AM : LBA 540349121 try REMAR...
4:49:54 AM : LBA 540349121 try REMAP... Error
4:49:55 AM : Block 540349122 Timeout
4:50:06 AM : LBA 540366536 try REMAR...
4:50:11 AM : LBA 540366536 try REMAP... Error
4:50:21 AM : Block 540366537 Timeout
4:50:35 AM : Block 540366793 Timeout
4:51:02 AM : LBA 540385071 try REMAR...
4:51:02 AM : LBA 540385071 try REMAP... Error
4:51:03 AM : Block 540385072 Timeout
4:51:46 AM : LBA 540402666 try REMAR...
4:51:46 AM : LBA 540402666 try REMAP... Error
4:52:02 AM : LBA 540402675 try REMAR...
4:52:08 AM : LBA 540402675 try REMAP... complete
4:52:09 AM : Block 540402676 Timeout
4:52:10 AM : Block 540420084 Timeout
4:52:56 AM : LBA 540437900 try REMAR...
4:52:56 AM : LBA 540437900 try REMAP... Error
4:52:57 AM : Block 540437901 Timeout
4:53:08 AM : LBA 540471830 try REMAR...
4:53:18 AM : LBA 540471830 try REMAP... Error
4:53:25 AM : LBA 540471880 try REMAR...
4:53:25 AM : LBA 540471880 try REMAP... Error
4:53:26 AM : Block 540471881 Timeout
4:53:29 AM : LBA 540480316 try REMAR...
4:53:31 AM : LBA 540480316 try REMAP... Error
4:53:31 AM : Block 540480317 Error: ABRT
4:53:39 AM : LBA 540483053 try REMAR...
4:53:39 AM : LBA 540483053 try REMAP... Error
4:53:40 AM : Block 540483054 Timeout
4:53:46 AM : LBA 540489495 try REMAR...
4:53:46 AM : LBA 540489495 try REMAP... Error
4:53:47 AM : Block 540489496 Timeout
4:53:50 AM : LBA 540498675 try REMAR...
4:53:50 AM : LBA 540498675 try REMAP... complete
4:53:51 AM : Block 540498676 Timeout
4:53:57 AM : LBA 540500668 try REMAR...
4:53:57 AM : LBA 540500668 try REMAP... complete
4:53:58 AM : Block 540500669 Timeout
4:54:10 AM : LBA 540507069 try REMAR...
4:54:10 AM : LBA 540507069 try REMAP... complete
4:54:17 AM : LBA 540507110 try REMAR...
4:54:17 AM : LBA 540507110 try REMAP... complete
4:54:20 AM : Block 540507111 Timeout
4:54:26 AM : LBA 540561895 try REMAR...
4:54:26 AM : LBA 540561895 try REMAP... complete
4:54:27 AM : Block 540561896 Timeout
4:54:28 AM : Warning! Block start at 540638696 = 173 ms
4:54:33 AM : Block 540860392 Timeout
4:54:35 AM : Block 540917224 Timeout
4:54:40 AM : LBA 540994457 try REMAR...
4:54:40 AM : LBA 540994457 try REMAP... complete
4:54:41 AM : Block 540994458 Timeout
4:54:57 AM : Warning! Block start at 542239130 = 135 ms
4:55:01 AM : LBA 542265968 try REMAR...
4:55:01 AM : LBA 542265968 try REMAP... complete
4:55:03 AM : Warning! Block start at 542265969 = 283 ms
4:55:03 AM : Block 542266225 Error: ABRT
4:55:06 AM : LBA 542272410 try REMAR...
4:55:06 AM : LBA 542272410 try REMAP... complete
4:55:07 AM : Block 542272411 Timeout
4:55:12 AM : LBA 542274984 try REMAR...
4:55:12 AM : LBA 542274984 try REMAP... complete
4:55:15 AM : LBA 542275147 try REMAR...
4:55:15 AM : LBA 542275147 try REMAP... complete
4:55:16 AM : Block 542275148 Timeout
4:55:21 AM : LBA 542281590 try REMAR...
4:55:21 AM : LBA 542281590 try REMAP... complete
4:55:22 AM : Block 542281591 Timeout
4:55:26 AM : LBA 542283583 try REMAR...
4:55:26 AM : LBA 542283583 try REMAP... complete
4:55:27 AM : Block 542283584 Timeout
4:55:32 AM : LBA 542292762 try REMAR...
4:55:32 AM : LBA 542292762 try REMAP... complete
4:55:33 AM : Block 542292763 Timeout
4:55:37 AM : LBA 542299205 try REMAR...
4:55:37 AM : LBA 542299205 try REMAP... complete
4:55:38 AM : Block 542299206 Timeout
4:55:43 AM : LBA 542308384 try REMAR...
4:55:43 AM : LBA 542308384 try REMAP... complete
4:55:44 AM : Block 542308385 Timeout
4:55:49 AM : LBA 542310377 try REMAR...
4:55:49 AM : LBA 542310377 try REMAP... complete
4:55:50 AM : Block 542310378 Timeout
4:56:11 AM : Block 542310890 Timeout
4:56:13 AM : Warning! Block start at 542316778 = 903 ms
4:56:13 AM : Warning! Block start at 542317034 = 128 ms
4:56:13 AM : Warning! Block start at 542317546 = 216 ms
4:56:19 AM : LBA 542459972 try REMAR...
4:56:19 AM : LBA 542459972 try REMAP... complete
4:56:20 AM : Block 542459973 Timeout
4:56:29 AM : LBA 542693936 try REMAR...
4:56:29 AM : LBA 542693936 try REMAP... complete
4:56:30 AM : Block 542693937 Timeout
4:56:38 AM : LBA 542869580 try REMAR...
4:56:38 AM : LBA 542869580 try REMAP... complete
4:56:39 AM : Block 542869581 Timeout
4:56:43 AM : LBA 542872317 try REMAR...
4:56:43 AM : LBA 542872317 try REMAP... complete
4:56:44 AM : Block 542872318 Timeout
4:56:51 AM : Block 543074558 Timeout
4:56:57 AM : LBA 543093113 try REMAR...
4:56:57 AM : LBA 543093113 try REMAP... complete
4:56:58 AM : Block 543093114 Timeout
4:57:03 AM : LBA 543095106 try REMAR...
4:57:03 AM : LBA 543095106 try REMAP... complete
4:57:04 AM : Block 543095107 Timeout
4:57:08 AM : LBA 543101549 try REMAR...
4:57:08 AM : LBA 543101549 try REMAP... complete
4:57:13 AM : LBA 543101777 try REMAR...
4:57:13 AM : LBA 543101777 try REMAP... complete
4:57:14 AM : Block 543101778 Timeout
4:57:18 AM : LBA 543104286 try REMAR...
4:57:18 AM : LBA 543104286 try REMAP... complete
4:57:19 AM : Block 543104287 Timeout
4:57:21 AM : Block 543110687 Timeout
4:57:27 AM : LBA 543119164 try REMAR...
4:57:27 AM : LBA 543119164 try REMAP... complete
4:57:28 AM : Block 543119165 Timeout
4:57:30 AM : Warning! Block start at 543139389 = 136 ms
4:57:32 AM : Warning! Block start at 543201597 = 249 ms
4:57:45 AM : Warning! Block start at 544267837 = 149 ms
4:58:03 AM : Warning! Block start at 545580605 = 583 ms
4:58:18 AM : Warning! Block start at 546759741 = 202 ms
4:58:19 AM : Warning! Block start at 546761789 = 185 ms
4:58:22 AM : LBA 546771116 try REMAR...
4:58:22 AM : LBA 546771116 try REMAP... complete
4:58:23 AM : Block 546771117 Timeout
4:58:25 AM : Warning! Block start at 546806189 = 143 ms
4:58:28 AM : LBA 546848762 try REMAR...
4:58:28 AM : LBA 546848762 try REMAP... complete
4:58:29 AM : Block 546848763 Timeout
4:58:32 AM : Block 546850555 Timeout
4:58:38 AM : LBA 546884736 try REMAR...
4:58:38 AM : LBA 546884736 try REMAP... complete
4:58:39 AM : Block 546884737 Timeout
4:58:41 AM : Warning! Block start at 546886529 = 212 ms
4:59:07 AM : Warning! Block start at 548774785 = 960 ms
4:59:09 AM : Warning! Block start at 548819329 = 436 ms
4:59:10 AM : Block 548854401 Timeout
4:59:16 AM : Block 548872833 Timeout
4:59:20 AM : Warning! Block start at 548934785 = 187 ms
4:59:21 AM : Warning! Block start at 548961665 = 292 ms
4:59:24 AM : LBA 548988596 try REMAR...
4:59:24 AM : LBA 548988596 try REMAP... complete
4:59:25 AM : Block 548988597 Timeout
4:59:34 AM : Block 549486261 Timeout
4:59:37 AM : LBA 549486519 try REMAR...
4:59:37 AM : LBA 549486519 try REMAP... complete
4:59:38 AM : Block 549486520 Timeout
4:59:43 AM : LBA 549491753 try REMAR...
4:59:43 AM : LBA 549491753 try REMAP... complete
4:59:44 AM : Block 549491754 Timeout
4:59:48 AM : LBA 549495693 try REMAR...
4:59:48 AM : LBA 549495693 try REMAP... complete
4:59:49 AM : Block 549495694 Timeout
4:59:54 AM : LBA 549500927 try REMAR...
4:59:54 AM : LBA 549500927 try REMAP... complete
4:59:55 AM : Block 549500928 Timeout
4:59:59 AM : LBA 549504138 try REMAR...
4:59:59 AM : LBA 549504138 try REMAP... complete
5:00:00 AM : Block 549504139 Timeout
5:00:05 AM : LBA 549509372 try REMAR...
5:00:05 AM : LBA 549509372 try REMAP... complete
5:00:06 AM : Block 549509373 Timeout
5:00:10 AM : LBA 549522487 try REMAR...
5:00:10 AM : LBA 549522487 try REMAP... complete
5:00:12 AM : Block 549522488 Timeout
5:00:16 AM : LBA 549527721 try REMAR...
5:00:16 AM : LBA 549527721 try REMAP... complete
5:00:17 AM : Block 549527722 Timeout
5:00:22 AM : LBA 549530932 try REMAR...
5:00:22 AM : LBA 549530932 try REMAP... complete
5:00:23 AM : Block 549530933 Timeout
5:00:27 AM : LBA 549545340 try REMAR...
5:00:27 AM : LBA 549545340 try REMAP... complete
5:00:29 AM : Block 549545341 Timeout
5:00:52 AM : LBA 549611312 try REMAR...
5:00:52 AM : LBA 549611312 try REMAP... complete
5:00:53 AM : Block 549611313 Timeout
5:01:06 AM : LBA 549634165 try REMAR...
5:01:06 AM : LBA 549634165 try REMAP... complete
5:01:07 AM : Block 549634166 Timeout
5:01:12 AM : LBA 549647280 try REMAR...
5:01:12 AM : LBA 549647280 try REMAP... complete
5:01:13 AM : Block 549647281 Timeout
5:01:27 AM : LBA 549709312 try REMAR...
5:01:27 AM : LBA 549709312 try REMAP... complete
5:01:28 AM : Block 549709313 Timeout
5:01:33 AM : LBA 549732165 try REMAR...
5:01:33 AM : LBA 549732165 try REMAP... complete
5:01:34 AM : Block 549732166 Timeout
5:01:39 AM : LBA 549768133 try REMAR...
5:01:39 AM : LBA 549768133 try REMAP... complete
5:01:40 AM : Block 549768134 Timeout
5:01:45 AM : LBA 549807312 try REMAR...
5:01:45 AM : LBA 549807312 try REMAP... complete
5:01:46 AM : Block 549807313 Timeout
5:01:52 AM : LBA 549843280 try REMAR...
5:01:52 AM : LBA 549843280 try REMAP... complete
5:01:53 AM : Block 549843281 Timeout
5:01:57 AM : LBA 549851725 try REMAR...
5:01:57 AM : LBA 549851725 try REMAP... complete
5:01:58 AM : Block 549851726 Timeout
5:02:03 AM : LBA 549860900 try REMAR...
5:02:03 AM : LBA 549860900 try REMAP... complete
5:02:04 AM : Block 549860901 Timeout
5:02:09 AM : LBA 549870074 try REMAR...
5:02:09 AM : LBA 549870074 try REMAP... complete
5:02:10 AM : Block 549870075 Timeout
5:02:14 AM : LBA 549878519 try REMAR...
5:02:14 AM : LBA 549878519 try REMAP... complete
5:02:15 AM : Block 549878520 Timeout
5:02:20 AM : LBA 549883753 try REMAR...
5:02:20 AM : LBA 549883753 try REMAP... complete
5:02:21 AM : Block 549883754 Timeout
5:02:26 AM : LBA 549887693 try REMAR...
5:02:26 AM : LBA 549887693 try REMAP... complete
5:02:27 AM : Block 549887694 Timeout
5:02:31 AM : LBA 549892927 try REMAR...
5:02:31 AM : LBA 549892927 try REMAP... complete
5:02:32 AM : Block 549892928 Timeout
5:02:37 AM : LBA 549896868 try REMAR...
5:02:37 AM : LBA 549896868 try REMAP... complete
5:02:38 AM : Block 549896869 Timeout
5:02:40 AM : Warning! Block start at 549928869 = 145 ms
5:03:13 AM : Block 552269733 Timeout
5:03:16 AM : LBA 552269991 try REMAR...
5:03:16 AM : LBA 552269991 try REMAP... complete
5:03:17 AM : Block 552269992 Timeout
5:03:22 AM : LBA 552277837 try REMAR...
5:03:22 AM : LBA 552277837 try REMAP... complete
5:03:23 AM : Block 552277838 Timeout
5:03:27 AM : LBA 552280411 try REMAR...
5:03:27 AM : LBA 552280411 try REMAP... complete
5:03:28 AM : Block 552280412 Timeout
5:03:33 AM : LBA 552286374 try REMAR...
5:03:33 AM : LBA 552286374 try REMAP... complete
5:03:34 AM : Block 552286375 Timeout
5:03:56 AM : LBA 552288256 try REMAR...
5:03:56 AM : LBA 552288256 try REMAP... complete
5:03:57 AM : Block 552288257 Timeout
5:04:01 AM : LBA 552296793 try REMAR...
5:04:01 AM : LBA 552296793 try REMAP... complete
5:04:02 AM : Block 552296794 Timeout
5:04:07 AM : LBA 552311293 try REMAR...
5:04:07 AM : LBA 552311293 try REMAP... complete
5:04:08 AM : Block 552311294 Timeout
5:04:13 AM : LBA 552319830 try REMAR...
5:04:13 AM : LBA 552319830 try REMAP... complete
5:04:14 AM : Block 552319831 Timeout
5:04:18 AM : LBA 552321712 try REMAR...
5:04:18 AM : LBA 552321712 try REMAP... complete
5:04:19 AM : Block 552321713 Timeout
5:04:43 AM : LBA 552327675 try REMAR...
5:04:43 AM : LBA 552327675 try REMAP... complete
5:04:44 AM : Block 552327676 Timeout
5:04:48 AM : LBA 552330249 try REMAR...
5:04:48 AM : LBA 552330249 try REMAP... complete
5:04:49 AM : Block 552330250 Timeout
5:05:03 AM : LBA 552336212 try REMAR...
5:05:03 AM : LBA 552336212 try REMAP... complete
5:05:04 AM : Block 552336213 Timeout
5:05:08 AM : LBA 552338095 try REMAR...
5:05:08 AM : LBA 552338095 try REMAP... complete
5:05:09 AM : Block 552338096 Timeout
5:05:14 AM : LBA 552344749 try REMAR...
5:05:14 AM : LBA 552344749 try REMAP... complete
5:05:15 AM : Block 552344750 Timeout
5:05:20 AM : LBA 552355168 try REMAR...
5:05:20 AM : LBA 552355168 try REMAP... complete
5:05:21 AM : Block 552355169 Timeout
5:05:25 AM : LBA 552361131 try REMAR...
5:05:25 AM : LBA 552361131 try REMAP... complete
5:05:26 AM : Block 552361132 Timeout
5:05:31 AM : LBA 552363014 try REMAR...
5:05:31 AM : LBA 552363014 try REMAP... complete
5:05:32 AM : Block 552363015 Timeout
5:05:37 AM : LBA 552371551 try REMAR...
5:05:37 AM : LBA 552371551 try REMAP... complete
5:05:38 AM : Block 552371552 Timeout
5:05:42 AM : LBA 552377514 try REMAR...
5:05:42 AM : LBA 552377514 try REMAP... complete
5:05:43 AM : Block 552377515 Timeout
5:05:48 AM : LBA 552393896 try REMAR...
5:05:48 AM : LBA 552393896 try REMAP... complete
5:05:49 AM : Block 552393897 Timeout
5:05:54 AM : LBA 552396470 try REMAR...
5:05:54 AM : LBA 552396470 try REMAP... complete
5:05:55 AM : Block 552396471 Timeout
5:05:59 AM : LBA 552410970 try REMAR...
5:05:59 AM : LBA 552410970 try REMAP... complete
5:06:00 AM : Block 552410971 Timeout
5:06:03 AM : Warning! Block start at 552429147 = 170 ms
5:06:19 AM : LBA 553420900 try REMAR...
5:06:19 AM : LBA 553420900 try REMAP... complete
5:06:20 AM : Block 553420901 Timeout
5:06:25 AM : LBA 553425777 try REMAR...
5:06:25 AM : LBA 553425777 try REMAP... complete
5:06:26 AM : Block 553425778 Timeout
5:06:30 AM : LBA 553429430 try REMAR...
5:06:30 AM : LBA 553429430 try REMAP... complete
5:06:31 AM : Block 553429431 Timeout
5:06:36 AM : LBA 553434307 try REMAR...
5:06:36 AM : LBA 553434307 try REMAP... complete
5:06:37 AM : Block 553434308 Timeout
5:06:41 AM : LBA 553437960 try REMAR...
5:06:41 AM : LBA 553437960 try REMAP... complete
5:06:42 AM : Block 553437961 Timeout
5:06:47 AM : LBA 553442837 try REMAR...
5:06:47 AM : LBA 553442837 try REMAP... complete
5:06:48 AM : Block 553442838 Timeout
5:07:04 AM : LBA 553445818 try REMAR...
5:07:04 AM : LBA 553445818 try REMAP... complete
5:07:05 AM : Block 553445819 Timeout
5:07:18 AM : LBA 553459225 try REMAR...
5:07:18 AM : LBA 553459225 try REMAP... complete
5:07:19 AM : Block 553459226 Timeout
5:08:06 AM : LBA 554698142 try REMAR...
5:08:06 AM : LBA 554698142 try REMAP... complete
5:08:07 AM : Block 554698143 Timeout
5:08:29 AM : LBA 554703019 try REMAR...
5:08:29 AM : LBA 554703019 try REMAP... complete
5:08:30 AM : Block 554703020 Timeout
5:08:49 AM : LBA 554706000 try REMAR...
5:08:49 AM : LBA 554706000 try REMAP... complete
5:08:50 AM : Block 554706001 Timeout
5:08:54 AM : LBA 554710877 try REMAR...
5:08:54 AM : LBA 554710877 try REMAP... complete
5:08:55 AM : Block 554710878 Timeout
5:09:00 AM : LBA 554714530 try REMAR...
5:09:00 AM : LBA 554714530 try REMAP... complete
5:09:01 AM : Block 554714531 Timeout
5:09:13 AM : LBA 554719407 try REMAR...
5:09:13 AM : LBA 554719407 try REMAP... complete
5:09:14 AM : Block 554719408 Timeout
5:09:28 AM : LBA 554723060 try REMAR...
5:09:28 AM : LBA 554723060 try REMAP... complete
5:09:29 AM : Block 554723061 Timeout
5:09:42 AM : LBA 554727937 try REMAR...
5:09:42 AM : LBA 554727937 try REMAP... complete
5:09:43 AM : Block 554727938 Timeout
5:09:47 AM : LBA 554730918 try REMAR...
5:09:47 AM : LBA 554730918 try REMAP... complete
5:09:48 AM : Block 554730919 Timeout
5:09:53 AM : LBA 554735795 try REMAR...
5:09:53 AM : LBA 554735795 try REMAP... complete
5:09:54 AM : Block 554735796 Timeout
5:09:58 AM : LBA 554739448 try REMAR...
5:09:58 AM : LBA 554739448 try REMAP... complete
5:09:59 AM : Block 554739449 Timeout
5:10:04 AM : LBA 554744325 try REMAR...
5:10:04 AM : LBA 554744325 try REMAP... complete
5:10:05 AM : Block 554744326 Timeout
5:10:27 AM : LBA 554747978 try REMAR...
5:10:27 AM : LBA 554747978 try REMAP... complete
5:10:28 AM : Block 554747979 Timeout
5:10:29 AM : Warning! Block start at 554755659 = 287 ms
5:11:58 AM : LBA 561012303 try REMAR...
5:11:58 AM : LBA 561012303 try REMAP... complete
5:11:59 AM : Block 561012304 Timeout
5:12:04 AM : LBA 561015956 try REMAR...
5:12:04 AM : LBA 561015956 try REMAP... complete
5:12:05 AM : Block 561015957 Timeout
5:12:10 AM : LBA 561020833 try REMAR...
5:12:10 AM : LBA 561020833 try REMAP... complete
5:12:11 AM : Block 561020834 Timeout
5:12:15 AM : LBA 561028691 try REMAR...
5:12:15 AM : LBA 561028691 try REMAP... complete
5:12:16 AM : Block 561028692 Timeout
5:12:21 AM : LBA 561032344 try REMAR...
5:12:21 AM : LBA 561032344 try REMAP... complete
5:12:22 AM : Block 561032345 Timeout
5:12:35 AM : LBA 561040874 try REMAR...
5:12:35 AM : LBA 561040874 try REMAP... complete
5:12:36 AM : Block 561040875 Timeout
5:12:43 AM : Warning! Block start at 561269227 = 218 ms
5:13:01 AM : LBA 561272995 try REMAR...
5:13:01 AM : LBA 561272995 try REMAP... complete
5:13:02 AM : Block 561272996 Timeout
5:13:18 AM : LBA 561286402 try REMAR...
5:13:18 AM : LBA 561286402 try REMAP... complete
5:13:19 AM : Block 561286403 Timeout
5:13:38 AM : LBA 561289383 try REMAR...
5:13:38 AM : LBA 561289383 try REMAP... complete
5:13:39 AM : Block 561289384 Timeout
5:14:01 AM : LBA 561294260 try REMAR...
5:14:01 AM : LBA 561294260 try REMAP... complete
5:14:02 AM : Block 561294261 Timeout
5:14:04 AM : Block 561310389 Timeout
5:14:26 AM : LBA 561310648 try REMAR...
5:14:26 AM : LBA 561310648 try REMAP... complete
5:14:27 AM : Block 561310649 Timeout
5:14:44 AM : LBA 561322831 try REMAR...
5:14:44 AM : LBA 561322831 try REMAP... complete
5:14:45 AM : Block 561322832 Timeout
5:15:01 AM : LBA 561327708 try REMAR...
5:15:01 AM : LBA 561327708 try REMAP... complete
5:15:02 AM : Block 561327709 Timeout
5:15:21 AM : LBA 561335566 try REMAR...
5:15:21 AM : LBA 561335566 try REMAP... complete
5:15:22 AM : Block 561335567 Timeout
5:15:44 AM : LBA 561339219 try REMAR...
5:15:44 AM : LBA 561339219 try REMAP... complete
5:15:45 AM : Block 561339220 Timeout
5:16:03 AM : LBA 561344096 try REMAR...
5:16:03 AM : LBA 561344096 try REMAP... complete
5:16:04 AM : Block 561344097 Timeout
5:16:24 AM : LBA 561347749 try REMAR...
5:16:24 AM : LBA 561347749 try REMAP... complete
5:16:25 AM : Block 561347750 Timeout
5:16:44 AM : LBA 561352626 try REMAR...
5:16:44 AM : LBA 561352626 try REMAP... complete
5:16:45 AM : Block 561352627 Timeout
5:16:47 AM : Block 561355443 Timeout
5:17:16 AM : LBA 561360484 try REMAR...
5:17:16 AM : LBA 561360484 try REMAP... complete
5:17:17 AM : Block 561360485 Timeout
5:17:37 AM : LBA 561364137 try REMAR...
5:17:37 AM : LBA 561364137 try REMAP... complete
5:17:38 AM : Block 561364138 Timeout
5:17:56 AM : LBA 561369014 try REMAR...
5:17:56 AM : LBA 561369014 try REMAP... complete
5:17:57 AM : Block 561369015 Timeout
5:18:00 AM : Block 561385143 Timeout
5:18:24 AM : LBA 561385402 try REMAR...
5:18:24 AM : LBA 561385402 try REMAP... complete
5:18:25 AM : Block 561385403 Timeout
5:18:42 AM : LBA 561389055 try REMAR...
5:18:42 AM : LBA 561389055 try REMAP... complete
5:18:43 AM : Block 561389056 Timeout
5:18:59 AM : LBA 561393932 try REMAR...
5:18:59 AM : LBA 561393932 try REMAP... complete
5:19:00 AM : Block 561393933 Timeout
5:19:18 AM : LBA 561397585 try REMAR...
5:19:18 AM : LBA 561397585 try REMAP... complete
5:19:19 AM : Block 561397586 Timeout
5:19:36 AM : LBA 561405443 try REMAR...
5:19:36 AM : LBA 561405443 try REMAP... complete
5:19:37 AM : Block 561405444 Timeout
5:19:59 AM : LBA 561413973 try REMAR...
5:19:59 AM : LBA 561413973 try REMAP... complete
5:20:00 AM : Block 561413974 Timeout
5:20:19 AM : LBA 561422503 try REMAR...
5:20:19 AM : LBA 561422503 try REMAP... complete
5:20:20 AM : Block 561422504 Timeout
5:20:41 AM : LBA 561430361 try REMAR...
5:20:41 AM : LBA 561430361 try REMAP... complete
5:20:42 AM : Block 561430362 Timeout
5:20:59 AM : LBA 561443768 try REMAR...
5:20:59 AM : LBA 561443768 try REMAP... complete
5:21:00 AM : Block 561443769 Timeout
5:21:19 AM : LBA 561476544 try REMAR...
5:21:19 AM : LBA 561476544 try REMAP... complete
5:21:20 AM : Block 561476545 Timeout
5:21:38 AM : LBA 561579869 try REMAR...
5:21:38 AM : LBA 561579869 try REMAP... complete
5:21:39 AM : Block 561579870 Timeout
5:21:56 AM : LBA 561601134 try REMAR...
5:21:56 AM : LBA 561601134 try REMAP... complete
5:21:57 AM : Block 561601135 Timeout
5:22:13 AM : LBA 561609664 try REMAR...
5:22:13 AM : LBA 561609664 try REMAP... complete
5:22:14 AM : Block 561609665 Timeout
5:22:31 AM : LBA 561617522 try REMAR...
5:22:31 AM : LBA 561617522 try REMAP... complete
5:22:32 AM : Block 561617523 Timeout
5:22:48 AM : LBA 561634582 try REMAR...
5:22:48 AM : LBA 561634582 try REMAP... complete
5:22:49 AM : Block 561634583 Timeout
5:23:08 AM : LBA 561637563 try REMAR...
5:23:08 AM : LBA 561637563 try REMAP... complete
5:23:09 AM : Block 561637564 Timeout
5:23:25 AM : LBA 561650970 try REMAR...
5:23:25 AM : LBA 561650970 try REMAP... complete
5:23:26 AM : Block 561650971 Timeout
5:23:45 AM : LBA 561654623 try REMAR...
5:23:45 AM : LBA 561654623 try REMAP... complete
5:23:46 AM : Block 561654624 Timeout
5:24:04 AM : LBA 561659500 try REMAR...
5:24:04 AM : LBA 561659500 try REMAP... complete
5:24:05 AM : Block 561659501 Timeout
5:24:22 AM : LBA 561662481 try REMAR...
5:24:22 AM : LBA 561662481 try REMAP... complete
5:24:23 AM : Block 561662482 Timeout
5:24:44 AM : LBA 561675888 try REMAR...
5:24:44 AM : LBA 561675888 try REMAP... complete
5:24:45 AM : Block 561675889 Timeout
5:25:01 AM : LBA 561684418 try REMAR...
5:25:01 AM : LBA 561684418 try REMAP... complete
5:25:02 AM : Block 561684419 Timeout
5:25:21 AM : LBA 561687399 try REMAR...
5:25:21 AM : LBA 561687399 try REMAP... complete
5:25:22 AM : Block 561687400 Timeout
5:25:41 AM : LBA 561692276 try REMAR...
5:25:41 AM : LBA 561692276 try REMAP... complete
5:25:42 AM : Block 561692277 Timeout
5:26:04 AM : LBA 561700806 try REMAR...
5:26:04 AM : LBA 561700806 try REMAP... complete
5:26:05 AM : Block 561700807 Timeout
5:26:21 AM : LBA 561703787 try REMAR...
5:26:21 AM : LBA 561703787 try REMAP... complete
5:26:22 AM : Block 561703788 Timeout
5:26:41 AM : LBA 561712317 try REMAR...
5:26:41 AM : LBA 561712317 try REMAP... complete
5:26:42 AM : Block 561712318 Timeout
5:26:58 AM : LBA 561717194 try REMAR...
5:26:58 AM : LBA 561717194 try REMAP... complete
5:26:59 AM : Block 561717195 Timeout
5:27:15 AM : LBA 561728705 try REMAR...
5:27:15 AM : LBA 561728705 try REMAP... complete
5:27:16 AM : Block 561728706 Timeout
5:27:38 AM : LBA 561733582 try REMAR...
5:27:38 AM : LBA 561733582 try REMAP... complete
5:27:39 AM : Block 561733583 Timeout
5:28:00 AM : LBA 561742112 try REMAR...
5:28:00 AM : LBA 561742112 try REMAP... complete
5:28:01 AM : Block 561742113 Timeout
5:28:03 AM : Warning! Block start at 561762081 = 143 ms
5:28:03 AM : Warning! Block start at 561791777 = 152 ms
5:28:14 AM : LBA 562165045 try REMAR...
5:28:14 AM : LBA 562165045 try REMAP... complete
5:28:15 AM : Block 562165046 Timeout
5:28:20 AM : LBA 562173575 try REMAR...
5:28:20 AM : LBA 562173575 try REMAP... complete
5:28:21 AM : Block 562173576 Timeout
5:28:25 AM : LBA 562176556 try REMAR...
5:28:25 AM : LBA 562176556 try REMAP... complete
5:28:26 AM : Block 562176557 Timeout
5:28:31 AM : LBA 562181433 try REMAR...
5:28:31 AM : LBA 562181433 try REMAP... complete
5:28:32 AM : Block 562181434 Timeout
5:28:37 AM : LBA 562185086 try REMAR...
5:28:37 AM : LBA 562185086 try REMAP... complete
5:28:38 AM : Block 562185087 Timeout
5:28:42 AM : LBA 562189960 try REMAR...
5:28:42 AM : LBA 562189960 try REMAP... complete
5:28:43 AM : Block 562189961 Timeout
5:28:56 AM : LBA 562193613 try REMAR...
5:28:56 AM : LBA 562193613 try REMAP... complete
5:28:57 AM : Block 562193614 Timeout
5:29:02 AM : LBA 562198484 try REMAR...
5:29:02 AM : LBA 562198484 try REMAP... complete
5:29:03 AM : Block 562198485 Timeout
5:29:08 AM : LBA 562201465 try REMAR...
5:29:08 AM : LBA 562201465 try REMAP... complete
5:29:09 AM : Block 562201466 Timeout
5:29:12 AM : Block 562214778 Timeout
5:29:34 AM : LBA 563549747 try REMAR...
5:29:34 AM : LBA 563549747 try REMAP... complete
5:29:35 AM : Block 563549748 Timeout
5:29:40 AM : LBA 563552728 try REMAR...
5:29:40 AM : LBA 563552728 try REMAP... complete
5:29:41 AM : Block 563552729 Timeout
5:29:46 AM : LBA 563557605 try REMAR...
5:29:46 AM : LBA 563557605 try REMAP... complete
5:29:47 AM : Block 563557606 Timeout
5:29:51 AM : LBA 563561258 try REMAR...
5:29:51 AM : LBA 563561258 try REMAP... complete
5:29:52 AM : Block 563561259 Timeout
5:29:55 AM : Block 563565867 Timeout
5:29:58 AM : LBA 563566135 try REMAR...
5:29:58 AM : LBA 563566135 try REMAP... complete
5:29:59 AM : Block 563566136 Timeout
5:30:39 AM : LBA 564486756 try REMAR...
5:30:39 AM : LBA 564486756 try REMAP... complete
5:30:40 AM : Block 564486757 Timeout
5:30:54 AM : LBA 564489737 try REMAR...
5:30:54 AM : LBA 564489737 try REMAP... complete
5:30:55 AM : Block 564489738 Timeout
5:30:59 AM : LBA 564494614 try REMAR...
5:30:59 AM : LBA 564494614 try REMAP... complete
5:31:00 AM : Block 564494615 Timeout
5:31:22 AM : LBA 564498267 try REMAR...
5:31:22 AM : LBA 564498267 try REMAP... complete
5:31:23 AM : Block 564498268 Timeout
5:31:28 AM : LBA 564503144 try REMAR...
5:31:28 AM : LBA 564503144 try REMAP... complete
5:31:29 AM : Block 564503145 Timeout
5:31:33 AM : LBA 564506797 try REMAR...
5:31:33 AM : LBA 564506797 try REMAP... complete
5:31:34 AM : Block 564506798 Timeout
5:31:36 AM : Warning! Block start at 564523182 = 161 ms
5:32:12 AM : LBA 566902748 try REMAR...
5:32:12 AM : LBA 566902748 try REMAP... complete
5:32:13 AM : Block 566902749 Timeout
5:32:18 AM : LBA 566907625 try REMAR...
5:32:18 AM : LBA 566907625 try REMAP... complete
5:32:19 AM : Block 566907626 Timeout
5:32:23 AM : LBA 566911278 try REMAR...
5:32:23 AM : LBA 566911278 try REMAP... complete
5:32:24 AM : Block 566911279 Timeout
5:32:29 AM : LBA 566916155 try REMAR...
5:32:29 AM : LBA 566916155 try REMAP... complete
5:32:30 AM : Block 566916156 Timeout
5:32:34 AM : LBA 566919808 try REMAR...
5:32:34 AM : LBA 566919808 try REMAP... complete
5:32:35 AM : Block 566919809 Timeout
5:32:40 AM : LBA 566932543 try REMAR...
5:32:40 AM : LBA 566932543 try REMAP... complete
5:32:41 AM : Block 566932544 Timeout
5:33:04 AM : LBA 567828247 try REMAR...
5:33:04 AM : LBA 567828247 try REMAP... complete
5:33:05 AM : Block 567828248 Timeout
5:33:10 AM : LBA 567839758 try REMAR...
5:33:10 AM : LBA 567839758 try REMAP... complete
5:33:11 AM : Block 567839759 Timeout
5:33:16 AM : LBA 567844635 try REMAR...
5:33:16 AM : LBA 567844635 try REMAP... complete
5:33:17 AM : Block 567844636 Timeout
5:33:21 AM : LBA 567848288 try REMAR...
5:33:21 AM : LBA 567848288 try REMAP... complete
5:33:22 AM : Block 567848289 Timeout
5:33:44 AM : LBA 567853165 try REMAR...
5:33:44 AM : LBA 567853165 try REMAP... complete
5:33:45 AM : Block 567853166 Timeout
5:33:58 AM : LBA 567856818 try REMAR...
5:33:58 AM : LBA 567856818 try REMAP... complete
5:33:59 AM : Block 567856819 Timeout
5:34:04 AM : LBA 567861695 try REMAR...
5:34:04 AM : LBA 567861695 try REMAP... complete
5:34:05 AM : Block 567861696 Timeout
5:34:10 AM : LBA 567864676 try REMAR...
5:34:10 AM : LBA 567864676 try REMAP... complete
5:34:11 AM : Block 567864677 Timeout
5:34:13 AM : Block 567869541 Timeout
5:34:55 AM : LBA 570509807 try REMAR...
5:34:55 AM : LBA 570509807 try REMAP... complete
5:34:56 AM : Block 570509808 Timeout
5:35:01 AM : LBA 570514684 try REMAR...
5:35:01 AM : LBA 570514684 try REMAP... complete
5:35:02 AM : Block 570514685 Timeout
5:35:07 AM : LBA 570518337 try REMAR...
5:35:07 AM : LBA 570518337 try REMAP... complete
5:35:08 AM : Block 570518338 Timeout
5:35:12 AM : LBA 570523214 try REMAR...
5:35:12 AM : LBA 570523214 try REMAP... complete
5:35:13 AM : Block 570523215 Timeout
5:35:18 AM : LBA 570526867 try REMAR...
5:35:18 AM : LBA 570526867 try REMAP... complete
5:35:19 AM : Block 570526868 Timeout
5:35:32 AM : LBA 570531744 try REMAR...
5:35:32 AM : LBA 570531744 try REMAP... complete
5:35:33 AM : Block 570531745 Timeout
5:35:38 AM : LBA 570534725 try REMAR...
5:35:38 AM : LBA 570534725 try REMAP... complete
5:35:39 AM : Block 570534726 Timeout
5:35:43 AM : LBA 570539602 try REMAR...
5:35:43 AM : LBA 570539602 try REMAP... complete
5:35:44 AM : Block 570539603 Timeout
5:35:50 AM : LBA 570580908 try REMAR...
5:35:50 AM : LBA 570580908 try REMAP... complete
5:35:51 AM : Block 570580909 Timeout
5:35:55 AM : LBA 570584561 try REMAR...
5:35:55 AM : LBA 570584561 try REMAP... complete
5:35:56 AM : Block 570584562 Timeout
5:36:10 AM : LBA 570597968 try REMAR...
5:36:10 AM : LBA 570597968 try REMAP... complete
5:36:11 AM : Block 570597969 Timeout
5:36:15 AM : LBA 570600949 try REMAR...
5:36:15 AM : LBA 570600949 try REMAP... complete
5:36:16 AM : Block 570600950 Timeout
5:36:21 AM : LBA 570614356 try REMAR...
5:36:21 AM : LBA 570614356 try REMAP... complete
5:36:22 AM : Block 570614357 Timeout
5:36:27 AM : LBA 570618009 try REMAR...
5:36:27 AM : LBA 570618009 try REMAP... complete
5:36:28 AM : Block 570618010 Timeout
5:36:33 AM : LBA 570630744 try REMAR...
5:36:33 AM : LBA 570630744 try REMAP... complete
5:36:34 AM : Block 570630745 Timeout
5:36:38 AM : LBA 570634397 try REMAR...
5:36:38 AM : LBA 570634397 try REMAP... complete
5:36:39 AM : Block 570634398 Timeout
5:36:44 AM : LBA 570639274 try REMAR...
5:36:44 AM : LBA 570639274 try REMAP... complete
5:36:45 AM : Block 570639275 Timeout
5:36:49 AM : LBA 570642927 try REMAR...
5:36:49 AM : LBA 570642927 try REMAP... complete
5:36:50 AM : Block 570642928 Timeout
5:36:55 AM : LBA 570647804 try REMAR...
5:36:55 AM : LBA 570647804 try REMAP... complete
5:36:56 AM : Block 570647805 Timeout
5:37:00 AM : LBA 570650785 try REMAR...
5:37:00 AM : LBA 570650785 try REMAP... complete
5:37:01 AM : Block 570650786 Timeout
5:37:06 AM : LBA 570655662 try REMAR...
5:37:06 AM : LBA 570655662 try REMAP... complete
5:37:07 AM : Block 570655663 Timeout
5:37:12 AM : LBA 570659315 try REMAR...
5:37:12 AM : LBA 570659315 try REMAP... complete
5:37:13 AM : Block 570659316 Timeout
5:37:17 AM : LBA 570672722 try REMAR...
5:37:17 AM : LBA 570672722 try REMAP... complete
5:37:18 AM : Block 570672723 Timeout
5:37:23 AM : LBA 570675703 try REMAR...
5:37:23 AM : LBA 570675703 try REMAP... complete
5:37:24 AM : Block 570675704 Timeout
5:37:29 AM : LBA 570689110 try REMAR...
5:37:29 AM : LBA 570689110 try REMAP... complete
5:37:30 AM : Block 570689111 Timeout
5:37:34 AM : LBA 570692763 try REMAR...
5:37:34 AM : LBA 570692763 try REMAP... complete
5:37:35 AM : Block 570692764 Timeout
5:37:40 AM : LBA 570705498 try REMAR...
5:37:40 AM : LBA 570705498 try REMAP... complete
5:37:41 AM : Block 570705499 Timeout
5:37:46 AM : LBA 570709151 try REMAR...
5:37:46 AM : LBA 570709151 try REMAP... complete
5:37:47 AM : Block 570709152 Timeout
5:37:52 AM : LBA 570721886 try REMAR...
5:37:52 AM : LBA 570721886 try REMAP... complete
5:37:53 AM : Block 570721887 Timeout
5:37:57 AM : LBA 570725539 try REMAR...
5:37:57 AM : LBA 570725539 try REMAP... complete
5:37:58 AM : Block 570725540 Timeout
5:38:20 AM : LBA 570734069 try REMAR...
5:38:20 AM : LBA 570734069 try REMAP... complete
5:38:21 AM : Block 570734070 Timeout
5:38:26 AM : LBA 570741927 try REMAR...
5:38:26 AM : LBA 570741927 try REMAP... complete
5:38:27 AM : Block 570741928 Timeout
5:38:32 AM : LBA 570750457 try REMAR...
5:38:32 AM : LBA 570750457 try REMAP... complete
5:38:33 AM : Block 570750458 Timeout
5:38:37 AM : LBA 570763864 try REMAR...
5:38:37 AM : LBA 570763864 try REMAP... complete
5:38:38 AM : Block 570763865 Timeout
5:38:43 AM : LBA 570766845 try REMAR...
5:38:43 AM : LBA 570766845 try REMAP... complete
5:38:44 AM : Block 570766846 Timeout
5:38:49 AM : LBA 570780252 try REMAR...
5:38:49 AM : LBA 570780252 try REMAP... complete
5:38:50 AM : Block 570780253 Timeout
5:38:54 AM : LBA 570783905 try REMAR...
5:38:54 AM : LBA 570783905 try REMAP... complete
5:38:55 AM : Block 570783906 Timeout
5:39:09 AM : LBA 570796640 try REMAR...
5:39:09 AM : LBA 570796640 try REMAP... complete
5:39:10 AM : Block 570796641 Timeout
5:39:14 AM : LBA 570800293 try REMAR...
5:39:14 AM : LBA 570800293 try REMAP... complete
5:39:15 AM : Block 570800294 Timeout
5:39:20 AM : LBA 570808823 try REMAR...
5:39:20 AM : LBA 570808823 try REMAP... complete
5:39:21 AM : Block 570808824 Timeout
5:39:26 AM : LBA 570816681 try REMAR...
5:39:26 AM : LBA 570816681 try REMAP... complete
5:39:27 AM : Block 570816682 Timeout
5:39:31 AM : LBA 570825211 try REMAR...
5:39:31 AM : LBA 570825211 try REMAP... complete
5:39:32 AM : Block 570825212 Timeout
5:39:37 AM : LBA 570838618 try REMAR...
5:39:37 AM : LBA 570838618 try REMAP... complete
5:39:38 AM : Block 570838619 Timeout
5:39:43 AM : LBA 570841599 try REMAR...
5:39:43 AM : LBA 570841599 try REMAP... complete
5:39:44 AM : Block 570841600 Timeout
5:39:48 AM : LBA 570855006 try REMAR...
5:39:48 AM : LBA 570855006 try REMAP... complete
5:39:49 AM : Block 570855007 Timeout
5:39:54 AM : LBA 570857987 try REMAR...
5:39:54 AM : LBA 570857987 try REMAP... complete
5:39:55 AM : Block 570857988 Timeout
5:40:00 AM : LBA 570871394 try REMAR...
5:40:00 AM : LBA 570871394 try REMAP... complete
5:40:01 AM : Block 570871395 Timeout
5:40:05 AM : LBA 570875047 try REMAR...
5:40:05 AM : LBA 570875047 try REMAP... complete
5:40:06 AM : Block 570875048 Timeout
5:40:20 AM : LBA 570887782 try REMAR...
5:40:20 AM : LBA 570887782 try REMAP... complete
5:40:21 AM : Block 570887783 Timeout
5:40:25 AM : LBA 570891435 try REMAR...
5:40:25 AM : LBA 570891435 try REMAP... complete
5:40:26 AM : Block 570891436 Timeout
5:40:31 AM : LBA 570899965 try REMAR...
5:40:31 AM : LBA 570899965 try REMAP... complete
5:40:32 AM : Block 570899966 Timeout
5:40:37 AM : LBA 570907823 try REMAR...
5:40:37 AM : LBA 570907823 try REMAP... complete
5:40:38 AM : Block 570907824 Timeout
5:40:42 AM : LBA 570916353 try REMAR...
5:40:42 AM : LBA 570916353 try REMAP... complete
5:40:43 AM : Block 570916354 Timeout
5:40:48 AM : LBA 570929760 try REMAR...
5:40:48 AM : LBA 570929760 try REMAP... complete
5:40:49 AM : Block 570929761 Timeout
5:40:54 AM : LBA 570932741 try REMAR...
5:40:54 AM : LBA 570932741 try REMAP... complete
5:40:55 AM : Block 570932742 Timeout
5:40:59 AM : LBA 570946148 try REMAR...
5:40:59 AM : LBA 570946148 try REMAP... complete
5:41:00 AM : Block 570946149 Timeout
5:41:05 AM : LBA 570949801 try REMAR...
5:41:05 AM : LBA 570949801 try REMAP... complete
5:41:06 AM : Block 570949802 Timeout
5:41:11 AM : LBA 570962536 try REMAR...
5:41:11 AM : LBA 570962536 try REMAP... complete
5:41:12 AM : Block 570962537 Timeout
5:41:16 AM : LBA 570966189 try REMAR...
5:41:16 AM : LBA 570966189 try REMAP... complete
5:41:17 AM : Block 570966190 Timeout
5:41:22 AM : LBA 570974719 try REMAR...
5:41:22 AM : LBA 570974719 try REMAP... complete
5:41:23 AM : Block 570974720 Timeout
5:41:28 AM : LBA 570978924 try REMAR...
5:41:28 AM : LBA 570978924 try REMAP... complete
5:41:29 AM : Block 570978925 Timeout
5:41:42 AM : LBA 570982577 try REMAR...
5:41:42 AM : LBA 570982577 try REMAP... complete
5:41:43 AM : Block 570982578 Timeout
5:41:48 AM : LBA 570991107 try REMAR...
5:41:48 AM : LBA 570991107 try REMAP... complete
5:41:49 AM : Block 570991108 Timeout
5:41:53 AM : LBA 570998965 try REMAR...
5:41:53 AM : LBA 570998965 try REMAP... complete
5:41:54 AM : Block 570998966 Timeout
5:41:59 AM : LBA 571007495 try REMAR...
5:41:59 AM : LBA 571007495 try REMAP... complete
5:42:00 AM : Block 571007496 Timeout
5:42:05 AM : LBA 571020902 try REMAR...
5:42:05 AM : LBA 571020902 try REMAP... complete
5:42:06 AM : Block 571020903 Timeout
5:42:10 AM : LBA 571023883 try REMAR...
5:42:10 AM : LBA 571023883 try REMAP... complete
5:42:11 AM : Block 571023884 Timeout
5:42:33 AM : LBA 571037290 try REMAR...
5:42:33 AM : LBA 571037290 try REMAP... complete
5:42:34 AM : Block 571037291 Timeout
5:42:39 AM : LBA 571040943 try REMAR...
5:42:39 AM : LBA 571040943 try REMAP... complete
5:42:40 AM : Block 571040944 Timeout
5:42:45 AM : LBA 571053678 try REMAR...
5:42:45 AM : LBA 571053678 try REMAP... complete
5:42:46 AM : Block 571053679 Timeout
5:42:50 AM : LBA 571057331 try REMAR...
5:42:50 AM : LBA 571057331 try REMAP... complete
5:42:51 AM : Block 571057332 Timeout
5:42:56 AM : LBA 571065861 try REMAR...
5:42:56 AM : LBA 571065861 try REMAP... complete
5:42:57 AM : Block 571065862 Timeout
5:43:02 AM : LBA 571073719 try REMAR...
5:43:02 AM : LBA 571073719 try REMAP... complete
5:43:03 AM : Block 571073720 Timeout
5:43:07 AM : LBA 571082249 try REMAR...
5:43:07 AM : LBA 571082249 try REMAP... complete
5:43:08 AM : Block 571082250 Timeout
5:43:22 AM : LBA 571095656 try REMAR...
5:43:22 AM : LBA 571095656 try REMAP... complete
5:43:23 AM : Block 571095657 Timeout
5:43:28 AM : LBA 571098637 try REMAR...
5:43:28 AM : LBA 571098637 try REMAP... complete
5:43:29 AM : Block 571098638 Timeout
5:43:33 AM : LBA 571112044 try REMAR...
5:43:33 AM : LBA 571112044 try REMAP... complete
5:43:34 AM : Block 571112045 Timeout
5:43:39 AM : LBA 571115025 try REMAR...
5:43:39 AM : LBA 571115025 try REMAP... complete
5:43:40 AM : Block 571115026 Timeout
5:43:45 AM : LBA 571128432 try REMAR...
5:43:45 AM : LBA 571128432 try REMAP... complete
5:43:46 AM : Block 571128433 Timeout
5:43:50 AM : LBA 571132085 try REMAR...
5:43:50 AM : LBA 571132085 try REMAP... complete
5:43:51 AM : Block 571132086 Timeout
5:43:56 AM : LBA 571144820 try REMAR...
5:43:56 AM : LBA 571144820 try REMAP... complete
5:43:57 AM : Block 571144821 Timeout
5:44:02 AM : LBA 571148473 try REMAR...
5:44:02 AM : LBA 571148473 try REMAP... complete
5:44:03 AM : Block 571148474 Timeout
5:44:07 AM : LBA 571157003 try REMAR...
5:44:07 AM : LBA 571157003 try REMAP... complete
5:44:08 AM : Block 571157004 Timeout
5:44:13 AM : LBA 571164861 try REMAR...
5:44:13 AM : LBA 571164861 try REMAP... complete
5:44:14 AM : Block 571164862 Timeout
5:44:19 AM : LBA 571173391 try REMAR...
5:44:19 AM : LBA 571173391 try REMAP... complete
5:44:20 AM : Block 571173392 Timeout
5:44:25 AM : LBA 571186798 try REMAR...
5:44:25 AM : LBA 571186798 try REMAP... complete
5:44:26 AM : Block 571186799 Timeout
5:44:30 AM : LBA 571189779 try REMAR...
5:44:30 AM : LBA 571189779 try REMAP... complete
5:44:31 AM : Block 571189780 Timeout
5:44:36 AM : LBA 571203186 try REMAR...
5:44:36 AM : LBA 571203186 try REMAP... complete
5:44:37 AM : Block 571203187 Timeout
5:44:41 AM : LBA 571206839 try REMAR...
5:44:41 AM : LBA 571206839 try REMAP... complete
5:44:43 AM : Block 571206840 Timeout
5:44:47 AM : LBA 571219574 try REMAR...
5:44:47 AM : LBA 571219574 try REMAP... complete
5:44:48 AM : Block 571219575 Timeout
5:45:10 AM : LBA 571223227 try REMAR...
5:45:10 AM : LBA 571223227 try REMAP... complete
5:45:11 AM : Block 571223228 Timeout
5:45:16 AM : LBA 571231757 try REMAR...
5:45:16 AM : LBA 571231757 try REMAP... complete
5:45:17 AM : Block 571231758 Timeout
5:45:22 AM : LBA 571239615 try REMAR...
5:45:22 AM : LBA 571239615 try REMAP... complete
5:45:23 AM : Block 571239616 Timeout
5:45:45 AM : LBA 571248145 try REMAR...
5:45:45 AM : LBA 571248145 try REMAP... complete
5:45:46 AM : Block 571248146 Timeout
5:45:50 AM : LBA 571256003 try REMAR...
5:45:50 AM : LBA 571256003 try REMAP... complete
5:45:51 AM : Block 571256004 Timeout
5:45:56 AM : LBA 571260880 try REMAR...
5:45:56 AM : LBA 571260880 try REMAP... complete
5:45:57 AM : Block 571260881 Timeout
5:46:01 AM : LBA 571264533 try REMAR...
5:46:01 AM : LBA 571264533 try REMAP... complete
5:46:02 AM : Block 571264534 Timeout
5:46:07 AM : LBA 571277940 try REMAR...
5:46:07 AM : LBA 571277940 try REMAP... complete
5:46:08 AM : Block 571277941 Timeout
5:46:13 AM : LBA 571280921 try REMAR...
5:46:13 AM : LBA 571280921 try REMAP... complete
5:46:14 AM : Block 571280922 Timeout
5:46:19 AM : LBA 571294328 try REMAR...
5:46:19 AM : LBA 571294328 try REMAP... complete
5:46:20 AM : Block 571294329 Timeout
5:46:33 AM : LBA 571297981 try REMAR...
5:46:33 AM : LBA 571297981 try REMAP... complete
5:46:34 AM : Block 571297982 Timeout
5:46:39 AM : LBA 571310716 try REMAR...
5:46:39 AM : LBA 571310716 try REMAP... complete
5:46:40 AM : Block 571310717 Timeout
5:46:44 AM : LBA 571314369 try REMAR...
5:46:44 AM : LBA 571314369 try REMAP... complete
5:46:45 AM : Block 571314370 Timeout
5:46:50 AM : LBA 571344164 try REMAR...
5:46:50 AM : LBA 571344164 try REMAP... complete
5:46:51 AM : Block 571344165 Timeout
5:46:56 AM : LBA 571347817 try REMAR...
5:46:56 AM : LBA 571347817 try REMAP... complete
5:46:57 AM : Block 571347818 Timeout
5:47:01 AM : LBA 571352694 try REMAR...
5:47:01 AM : LBA 571352694 try REMAP... complete
5:47:02 AM : Block 571352695 Timeout
5:47:07 AM : LBA 571355675 try REMAR...
5:47:07 AM : LBA 571355675 try REMAP... complete
5:47:08 AM : Block 571355676 Timeout
5:47:13 AM : LBA 571369082 try REMAR...
5:47:13 AM : LBA 571369082 try REMAP... complete
5:47:14 AM : Block 571369083 Timeout
5:47:18 AM : LBA 571372735 try REMAR...
5:47:18 AM : LBA 571372735 try REMAP... complete
5:47:19 AM : Block 571372736 Timeout
5:47:24 AM : LBA 571376940 try REMAR...
5:47:24 AM : LBA 571376940 try REMAP... complete
5:47:25 AM : Block 571376941 Timeout
5:47:30 AM : LBA 571380593 try REMAR...
5:47:30 AM : LBA 571380593 try REMAP... complete
5:47:31 AM : Block 571380594 Timeout
5:47:35 AM : LBA 571385470 try REMAR...
5:47:35 AM : LBA 571385470 try REMAP... complete
5:47:36 AM : Block 571385471 Timeout
PostPosted: March 27th, 2007, 18:11
most of the errors are removed u can use the hdd again and u r using the windows version i use dos version 3.33 .
PostPosted: March 27th, 2007, 18:35
I am still not able to access the files off the hard drive. Windows just asks if I'd like to format:
Here is a screenshot of what my box looks like:
Upon further reading, others had suggested it is a partition table error?
Besides doing the REMAP scan with Victoria, is there any other ways of accessing the files on the drive?
PostPosted: March 28th, 2007, 2:56
no for fixing the partition table structure use testdisk .
PostPosted: March 28th, 2007, 18:00
Is that the only reason I can not still access my hard drive?
Or would there be other reasons?
I am afraid of running TestDisk if the partition tables are okay; and it would ruin my data :S
PostPosted: March 28th, 2007, 18:18
then send it to a DR company .
PostPosted: March 28th, 2007, 18:33
yes, agree.
If data important then do not try to DIY, you willl make it worse, and more expensive!!
PM me.
PostPosted: March 28th, 2007, 19:09
The data is not important, theres just a lot of it- so getting it back would be time consuming and annoying (but possible)
Does this sound like a partition table problem to you ?
Users browsing this forum: Google [Bot] and 302 guests
