 Post subject: SA writing test failed
PostPosted: March 29th, 2007, 14:47
I have Maxtor 2b020h1 whose uba have errors and glist is corrupt and also it shows Maxtor Athena here is what i did .
1> Put hdd in Safe mode .
2> Load approprite LDR , LDR loaded successfully .
3> Check modules and uba , Glist was bad and uba had error from 391- 400.
4> Write good Glist module , written successfully .
5> Then i check SA structure again same problem Glist still bad .
6> Then i did SA writing test it said "Error unloading adaptives" then it was checking for something in uba after sometime it said displacement not calculated .
What is this problem and how to fix ?
Thanks in advance .
 Post subject: Re: SA writing test failed
PostPosted: March 31st, 2007, 2:49
Thanks in advance .
if SA write test failed : Nothing can be done. Recording other firmware is useless, since nothing is written to SA.
As you can see G-List is still bad even you have rewrite it. That's because nothing is recorded to the corrupted SA.
PS : Why don't you try Clear G-List ?
 Post subject:
PostPosted: March 31st, 2007, 14:20
If G-List is corrupt is it possible to clear it .
Users browsing this forum: Google [Bot], Lukas and 180 guests
