Blue Screen in Monitor
April 23rd, 2008, 12:45
I have a HDD MAXTOR 30 GB....the problem is when i connected the HDD and tURN oN computer always appear THE BLUE SCREEN in Monitor after BIOS INFORMATION. But when i not connected the MAXTOR n i connected the other HDD my cpu is normally.
AnyBodys Who have A SOLVING.
Re: Blue Screen in Monitor
April 23rd, 2008, 14:55
Hi
What does the blue screen say? Which module causes what exception?
Check the drive in MHDD and see if it has bad sectors first.
April 23rd, 2008, 18:56
I saw this once a while ago. I didn't bother seeing what the cause was, but the solution was to remove all partitions and format. If you need the data, an external case may help.
April 24th, 2008, 1:51
Yes, I am suspecting FileSystem damage that causes NTFS.sys to cause errors, that's why I am asking.
April 24th, 2008, 10:15
Agreed :)
