 Post subject: Seagate ST340014A
PostPosted: April 2nd, 2007, 2:21
Hi All
i have a Segate Barracuda 7200.7 St 340014A, it spins up correctly but does not get seen by the bios, i have tried mhdd and copyr and none of these see the drive, i have tried a different board on the bottom and same thing still happens.
i suspect mabye the head is not moving correctly internally, has anyone had this or a similar problem with these drives?
thx in advance
PostPosted: April 2nd, 2007, 2:29
This is a very common problem in Seagate Barracuda drives put your hand on the drive while it is powered and check if there is very low clicking or not .
 Post subject: Seagate Barracuda ST340014A Problem
PostPosted: April 9th, 2007, 12:32
I have a Seagate Barracuda 7200.7 St 340014A (40GB) with following problems:
1. It does not get detected by the bios.
2. The drive does make continously clicking noise.
Please help me and suggest remedies to recover very important data from it.
Thanks in advance.
Rahim
PostPosted: April 9th, 2007, 16:25
U need to chk hdd in Terminal . Then post log here .
Users browsing this forum: Google [Bot] and 259 guests
