April 7th, 2007, 18:27
Does someone know the procedure for starting selfscan on Maxtor quantam drives ?
I need to start selfscan on Maxtor D540X-4K 40gb drive .
Do u have to load the .sso file or just start selfscan or is there any way .
if selfscan requires loading a file please provide for this drive .
Thanks in advance .
April 9th, 2007, 16:31
no one use Quantam selfscan here .
April 10th, 2007, 5:00
I have only selfscan of PCMX740, did you need?
April 10th, 2007, 14:50
yes please share and also tell me the procedure .
thanks
April 10th, 2007, 23:17
Click here to download 740X-6L selfscan
http://rapidshare.com/files/25372380/pcmx740l.sso
To run selfscan of 740X-6L, you must have PC3K-ISA.
April 11th, 2007, 16:22
yes i do have pc3k isa this is what i do to start self scan on these drives :
1) load the .sso file .
2) then start selfscan .
3) then disconnect the hdd and connect to a external power supply .
4) After 2 minutes the led is blinking and keeps on blinking.
nothing happens after that i have left the hdd on power supply for 2days still the light is blinking .
Whats did i do wrong here ?
