 Post subject: SeaGate ST380011A ERROR
PostPosted: April 4th, 2007, 23:31
Respected Guru
I have a seagate hard disk ST380011A ( 8.01). When i power up the hard disk it tries to initilize the head but can not do but after some time it detects it self. and give error ( here is terminal report)
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk M-21 11-25-03 18:53
Spin Ready
8.01 03-18-05 15:46
(P)PATA Reset
Not Interface Age!
NIWOT TIME OUT
AutoRd Err 43 at 00e32f.00.0173
AutoRd Err 47 at 00e32f.00.0000
INVALID Cert Disk Code - ROM Resident Revision Required: 8.01
Command Inactive - No VALID Cert Code Detected
I need data. Do I have to change head. please guide me
DF
PostPosted: April 5th, 2007, 2:07
Not Interface Age!
What is the interface age? Some extra info as answer on . ; % will be nice.
DataRecovery.bg
 Post subject: Thanks
PostPosted: April 5th, 2007, 2:13
Dear Samo Sir
Thanks for your reply here is more terminal report.
T>Age=50 Type=21 MxCyl=16358 MxHd=1 MxSct=44C BSz=0000 TCode=0000
T>
:5000000821000001 AX`5JVXVCGC "000000000000"0F68E-0F70D
SRAM Ovly = Diag
DF
PostPosted: April 5th, 2007, 3:02
Something does not fit here.
IMHO the PCB is not native.
DataRecovery.bg
 Post subject: Solved
PostPosted: April 5th, 2007, 15:19
Thankyou to all Guru's
Problem Solved have to change head (dirty head)
Thanks and regards
DF
Users browsing this forum: Google [Bot] and 255 guests
