 Post subject: CHKDSK discovered free space marked as allocated in the volu
PostPosted: April 9th, 2007, 4:05
I'm using 250 GB Seageate Bercudda SATA HDD
When I did the CHKDSK using windows XP it displayed the following error
(C:)
CHKDSK is verifying security descriptors (stage 3 of 3)...
Security descriptor verification completed.
CHKDSK discovered free space marked as allocated in the volume bitmap.
Windows found problems with the file system.
Run CHKDSK with the /F (fix) option to correct these.
there are no bad sectors availabe in the HDD
then i formatted the partition C: with FAT32 and then reformatted it using NTFS and reinstalled the OS
After formatting i did the CHKDSK utility again, but the previous error was not sloved.
What can I do to overcome this issue.
Any one pls help me immediatly
PostPosted: April 9th, 2007, 6:04
When you re-formatted, did you actually remove the partition, or just format?
You at least need to remove partition, re boot and re-create partition.
Sometimes you need to low level format the drive.
Hope this helps
PostPosted: April 17th, 2007, 4:19
Chkdsk will mark these space as free so the file system can use it.
software reviews
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 284 guests
