 Post subject: How to clear ROM
PostPosted: April 17th, 2007, 2:59
Hello to all gurus.
I have a samll question. if serial rom i.e 25P10VP is corupted and hard disk gives only BSY or no signal how to clear it and make drive working.
DF
 Post subject:
PostPosted: April 17th, 2007, 3:19
What's the drive you're talking about and how do you know you have the serial rom corrupted?
 Post subject:
PostPosted: April 17th, 2007, 3:30
WD. I was working on it. disk stared working fine I cloned the disk. when i copied data from cloned hard disk it was displaying garbage. altough raw recovery give me good results but client want it with file name. so I again plugged the disk in the pc3000 card and it has again started showing me its factory alies. I have copied the previous rom when it was showing factory alies and when it started showing correctly. I just copied the second ( when displaing correct model) after that disk is not powering up. This happend only after coping ROM i am searching for the same IC but I want to flash it so needed guidence . If you want you can PM me
here is the previous problem posting
http://forum.hddguru.com/need-help-for- ... t6960.html
Please help
DF
Users browsing this forum: Majestic-12 [Bot] and 245 guests
