 Post subject: IBM Ultrastar 146GB disk limited to 37GB
PostPosted: April 12th, 2007, 15:17
I have 4 IBM Ultrastar 146GB U320 SCSI HDD's which are limited to 37GB, they were replacements for 4 broken 36GB drives
I was wondering if it is possible to remove this limit and use the full 146GB
IBM part: 08K0322
Model: IC35L146UWDY10-0
Firmware: S25F
man.dates: Jun-2002 / Sep-2002
On the sticker it says: Capacity: 146 GB so my best guess they are 146GB drives with a 36GB firmware?!
I have been looking for firmwares for these drives but have found none as Hitachi only gives them out when needed, don't think i'll get them when I ask ;)
I found some references to 146GB firmwares while googling: S21E & S23C
Does anyone have an idea?
PostPosted: April 12th, 2007, 15:39
They appear to be HPA "clipped".
Easy to fix on IDE drives (MHDD will do it), but not sure about SCSI.
PostPosted: April 12th, 2007, 16:21
MHDD returns an "IDE only" message so this won't work
PostPosted: April 12th, 2007, 22:48
Only one thing can work with SCSI HDD, PC3000- SCSI version. So you must send your drive to a lab, where's have that tool.
PostPosted: April 13th, 2007, 3:28
That's right. You have no free tool that can work with scsi drives.
PostPosted: April 13th, 2007, 11:12
Thanks for the info
Sending them off to a lab will most likely cost more then getting 146GB drives so I'll leave them as they are now
PostPosted: April 13th, 2007, 13:35
I can help you, if you want. I'm Vietnamesse and my lab have PC3000-SCSI.
Users browsing this forum: No registered users and 318 guests
