 Post subject: Seagate HDD password lock out
PostPosted: April 12th, 2007, 15:04
Hello there,
Can anyone help please, my acer laptop is locked out with a HDD password.
It's seagate Momentus 60 GB. Does any one know the default password or a way round it. Many thanks
 Post subject:
PostPosted: April 12th, 2007, 15:18
1. PC3000
2. AFF Repair Station
 Post subject:
PostPosted: April 13th, 2007, 3:31
If this is a unique case it's much cheapper to use AFF.
PostPosted: April 13th, 2007, 5:18
Hi guys, thanks for your advice.
will try these options, In the mean time does anyone know the master password, as I noticed on a previous post a user had a similar problem and a master password was available. Thanks guys.
 Post subject:
PostPosted: April 13th, 2007, 11:20
Hi guys, Not having much luck so far, AFF doesn't support Seagate Momentus hard drives.
 Post subject:
PostPosted: April 13th, 2007, 11:25
Then the only option is really using PC3K.
If you don't have it, contact someone that has it.
 Post subject:
PostPosted: April 13th, 2007, 14:19
The dafault hdd master pasword is: "Vendor_name" + XXXX =32 Symbols
Where XXX- stand as alias of "Space", and "Vendor_name" is alias of the name of current vendor :) . Capital letter have matter.
Anyway i do not think this would help since usually laptop change the master pass to some unprinted characters that can't be typed.
DataRecovery.bg
 Post subject:
PostPosted: April 17th, 2007, 2:27
Hi.Try the master password "seagate+20 space".
Good luck!
SalvationDATA--Profesionnal Hard drive solution Provider. MSN: sales.laura@salvationdata.com
 Post subject:
PostPosted: April 18th, 2007, 4:27
Good luck!
This is not the master password for seagate drives !! .
The right Master password is as Samo said in his hint.
Users browsing this forum: No registered users and 267 guests
