 Post subject: Maxtor Diamond Max PLus 9
PostPosted: April 10th, 2007, 23:54
Hello to all people
Does anyone know on Diamond Max Plus 9 6Y200P0 have adaptive information on serial ROM? why because this patient had ROM serial burned
Thanks for all
 Post subject:
PostPosted: April 11th, 2007, 14:37
U can use other calypso PCBs for this model. Your bigger problem is that probably the preamp is burnt too since it receives the 5V directly and this line has probably failed that caused the ROM to burn too.
(However it is a bit odd, because it runs from 3.3V.)
regards,
 Post subject:
PostPosted: April 11th, 2007, 15:02
pepe wrote:
.......the ROM to burn too.
where is that ROM ???
 Post subject: Thanks peter
PostPosted: April 12th, 2007, 15:09
Hello peter
The hard disk have a head sticktion the head its not on land zone, its near from the begin of the platter, so im think this was the cause wich burn the spindle controller and ROM.
Im going to try , solving this problem and getting another Donnor PCB, so ROM its not adpative right?
Best Regards
 Post subject:
PostPosted: April 15th, 2007, 23:27
This is no Masked ROM inside Microcontroller, its external 8 pins
 Post subject:
PostPosted: April 16th, 2007, 10:00
Forget about ROM.
Just find another PCB with the same CPU (Ardent C8-C1 for example) and see how it works.
Users browsing this forum: Google [Bot] and 84 guests
