 Post subject: Maxtor Proxima?
PostPosted: April 19th, 2007, 11:49
I'm having a problem with a Maxtor 3400 (model 31024H1, code YAH814Y0, TI DSP chipset) that is being detected as Proxima. From what I've gathered, Proxima is the drive's factory name, meaning that there's a problem with the HDD firmware.
Anyone knows how I can recover the data off it? Would swapping the logic board with an identical one help or is there another simpler cost-effective (non-PC3000) way?
Any suggestion would be appreciated. TIA.
 Post subject:
PostPosted: April 19th, 2007, 13:14
Swapping the pcb wont do u any good as the firmware is stored on the HDA , and for fixing this problem u can use HDD repair it can fix firmware problems but not all of them , its quite a limited tool but u can give it a try .
 Post subject:
PostPosted: April 19th, 2007, 14:01
rameez:
Thanks for the suggestion. I'll give this a go. By HDD Repair, did you mean Flobo HDD Repair?
 Post subject:
PostPosted: April 19th, 2007, 14:18
no i mean hdd repair 1.1 or hdd repair 2.0 .
 Post subject:
PostPosted: April 19th, 2007, 14:37
rameez:
I see. Would you happen to know of where to download this HDD Repair?
PostPosted: April 19th, 2007, 17:49
There are no way to repair SA problem swapping PCB´s SA its microcode, stored on platter after manufacturer.
U need tool´s wich be able to access or manage Vendor Commands for Access - cyl like Ace, BVG, etc
 Post subject:
PostPosted: April 22nd, 2007, 7:36
Does the hdd click when it is powered?
Users browsing this forum: No registered users and 256 guests
