 Post subject: 4d040h2 pcb problem .
PostPosted: April 24th, 2007, 14:09
Someone has schematic for 4D0 <Romulus> drives as i have many hdd with no power in pcb , or someone could tell me what are most of the problems in these kind of pcbs .
 Post subject:
PostPosted: April 24th, 2007, 18:24
Could be the motor combo (SH6770), or the 3.3V regulator transistor, or something else :)
I would give it 3.3V to the proper point, check the clock signal at the crystal, if it is OK, then pull up the -POR line and see if there is any activity on the RAM address and data lines.
if these are OK, most probably the motor combo is damaged.
But of course these are only raw guidelines, there could be anything else causing the problem.
regards,
 Post subject:
PostPosted: April 25th, 2007, 13:44
Thanks for reply .
One more thing i need to ask u is there any fuse on this hdd ?
 Post subject:
PostPosted: April 28th, 2007, 4:26
I don't think so.
 Post subject:
PostPosted: April 29th, 2007, 15:51
no fuse in harddisk friend :)
 Post subject:
PostPosted: April 29th, 2007, 16:04
There are fuses on pcbs on some hdds but i was not sure about this hdd .
Thanks for reply
 Post subject:
PostPosted: April 29th, 2007, 23:09
Rameeze check L201, 202 203 &204 by power connector Q502 has 5v on 1 leg (closest to IDE connector)& 3.3 on other. U 503, 504, & 505 need to be good for motor to work. Rest is the same for the schematic you have. If you want me to give you some readings post what you need I have a few working drives so I can check.
I think ST is a sub company of Lucas
 Post subject:
PostPosted: May 1st, 2007, 7:44
I will chk these points and give u update
thanks for help
Users browsing this forum: Google [Bot] and 265 guests
