 Post subject: ST3160023A hanging
PostPosted: April 28th, 2007, 4:32
this drive had a burnt PCB, preamp, do the heads were swapped. Now it is detected correctly after a while, I can read the data surface, but it hangs at various places and sometimes it reads from some different LBA without any error message (when I re-read the same sector, the content is different, and correct).
here is the log on power up:
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk M.14 01-16-03 11:51
Buzz - Head Mask 000F - Switch to full int.
Spin Ready
3.06 02-17-04 10:59
(P)PATA Reset
CE Log EC=0 Rtype=36 OV=0 STStatus0
AutoRd Err 43 at 00f6ba.00.008b
Read Ver Retrys
Read Ver Retrys
$Switch to full int.
AutoRd Err 43 at 00f6ba.00.0095
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Master
thankx,
 Post subject:
PostPosted: April 28th, 2007, 9:21
Hi, pepe
seems like head 0 lose the servo sometimes.
What is the f/w version, and serial number?
DataRecovery.bg
 Post subject:
PostPosted: April 28th, 2007, 14:48
FW:3.06
SN: 5JS298AS
can U figure out something from these?
thx,
 Post subject:
PostPosted: May 2nd, 2007, 6:18
hi pepe,
Seems bad sectors in SA ..and also seems head Can not read surface properlly..may be smoke or dust there..?
Check all defectlist are they ok?
 Post subject:
PostPosted: May 3rd, 2007, 6:45
pepe wrote:
FW:3.06
SN: 5JS298AS
thx,
From serial Number it have 4 head. there is two type of serial number for 4 head, the others one is begin with XLJXXXXX.
How about your donor Drive . is it have same serial name begin with XJSXXXXX
 Post subject:
PostPosted: May 3rd, 2007, 17:16
I have tried 2 donors, both has been opened previously, so I am not sure about the heads, but both were more or less working drives. One had JS and the other had LJ in the SN.
I will try a JS from a fully working drive...
thankx for the suggestions from all of U!
I will keep U informed.
Users browsing this forum: No registered users and 206 guests
