 Post subject: can i read and write wd800bb fja0 rom using programmer
PostPosted: May 1st, 2007, 15:15
salam alekm
 Post subject:
PostPosted: May 2nd, 2007, 15:15
hi,
Of course. Now I am using EETools Topmax, but I built a simple programmer through the paralel port and wrote some code in assembly for reading/writing M25Pxx before I bought that programmer. It is not that difficult...
regards,
 Post subject: i have programmer and converter but dont know how to do it?
PostPosted: May 3rd, 2007, 10:41
salam alekm
i have programmer and arapter but dont know how to do it?
i have adapter for my programmer to programm the serial ic with 8 legs but which direction i put the ic i dont know
 Post subject:
PostPosted: May 3rd, 2007, 17:21
Pin 1 is marked on the case either with a dot, or by cutting one edge in ~45 degrees (turn this cutting to face towards U, pin1 is the bottom-left pin).
U may also download the datasheet of the IC and see the parameters of the casing.
regards,
 Post subject: plz i need the data sheet of the ic and your circuit
PostPosted: May 4th, 2007, 15:47
salam alekm
please ms pepe i want data sheet of the rom ic and your simple circuit as iam afriad of making mistake with my programmer burn it so i want to try with your circuit first
 Post subject:
PostPosted: May 4th, 2007, 16:44
I am afraid it is more likely u make a mistake with my circuit than with the programmer. ... and to be honest I don't have a drawing of it...
And of course U would need the prog also to make it work.
It is much easier to use an existing programmer than to build one, I didn't have one and it was a weekend, so I had to build it soon :)
U can find the datasheet on the web, use google!
M25P05, or M25P10, they are the same except M25P05 is 64KB, while M25P10 is 128 KB.
regards,
 Post subject:
PostPosted: May 4th, 2007, 17:36
Maxword take a look at http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=3081. It's a turnkey unit affordable and supports lots of chips so you can re-program motherboard bios as well. :D
I think ST is a sub company of Lucas
 Post subject:
PostPosted: May 5th, 2007, 4:15
Can u lady give me number of ic and program to make circit and component and circuit
Users browsing this forum: No registered users and 252 guests
