 Post subject: WD 0mb .
PostPosted: April 14th, 2007, 15:21
I have a Wd200eb-11cpf0 that shows 0mb and shows its drive id wd205eb.
whats the problem and how can it be solved.
I just need to repair hdd .
Thanks in advance .
 Post subject:
PostPosted: April 15th, 2007, 3:37
Logic board was replaced...?
SA modules was checked...?
Module 42 is not damaged...?
Mikippp
 Post subject:
PostPosted: April 16th, 2007, 3:41
That happens many times when someone replaces pcb and write wrong firmware.
 Post subject:
PostPosted: April 16th, 2007, 17:02
So i should change pcb ?
Or can this be a ROM problem ?
 Post subject:
PostPosted: April 16th, 2007, 17:28
Rather problem with WDC TALON ...
Can you read ~id42 module?
Mikippp
 Post subject:
PostPosted: April 17th, 2007, 15:40
yes i am able to read the id42 module .
 Post subject:
PostPosted: April 22nd, 2007, 17:14
If logic board and ROM are compatible with HDA...
And You can read ~id42 module...
I think that ~id42 module is damaged / have incorrect Check Sum /
If model name in ~id42 module is incorrect then drive is detected without model extension -11CPF0
Check list of supported models in ROM...
Mikippp
 Post subject:
PostPosted: April 23rd, 2007, 11:43
If you are able to read module 42 - you should be able to check modules in SA.
Any problems with them?
 Post subject:
PostPosted: May 6th, 2007, 15:15
your question : I have a Wd200eb-11cpf0 that shows 0mb and shows its
drive id wd205eb.
answer for RAMEEZ
mr.rameez u have to learn more in WD..
:D
you should know which pcb is compatible with the model..FIRST..
well if wrong pcb u put in the drive then id 42( hdd config id) will show damage..
first u should place a correct pcb with goods working then u can check
then check structure test see which modules is bad replace with good one
IF DONT SHOW NORMALLY PUT JUMPER IN SAFE MODE AND WRITE ROM AND CHECK IN STANDARD MODE SEE ..
CHECK STRUCTURE TEST WHICH MODULE IS BAD REPLACE WITH GOOD ONE..
I HOPE U CAN DO IT.. PLS READ PC3000 MANUAL CAREFULLY OF WD
U WILL FIND MANY ANSWERS OF YOURS..
 Post subject:
PostPosted: May 6th, 2007, 15:16
U CAN EASILY WORK WITH HD DOCTOR FOR WD..
TRY IT :)
 Post subject:
PostPosted: May 8th, 2007, 1:04
i solved the problem the problem was in ROM i wasnt able to write ROM with pc3k found a matching ROM and changed it with the faulty ROM its working fine now .
Thanks for reply .
Users browsing this forum: SWM and 363 guests
