 Post subject: HEllp can pcb for 00fja0 work on 88jhc0
PostPosted: May 7th, 2007, 16:06
how can i see replace hdd with its pcb by pcb from different model and it work good ,isee wd800bb-88jhc0 power ic(L6283 1.3) 2060-701292-000, its pcb replaced by 2060-001130-012 and work so the hdd now model is wd800bb-88jhco and it have pcb 2060-001130-012 so ho it can?
i saw many with this so how?, i saw many hdd replace pcb by another and it work?? so any onw explain me
 Post subject:
PostPosted: May 8th, 2007, 1:13
it may be because ROM code must be the same for both pcbs .
 Post subject: Just want to know how this done and the power circuit
PostPosted: May 8th, 2007, 2:18
Just want to know how this done and the power circuit is different how the hdd not damage
 Post subject:
PostPosted: May 8th, 2007, 16:00
curcuit must have beeen physically designed in another shape but does the same thing . Have u seen the ROM info in wd drives they say that this rom can support for 20,40,80,120 gb . The ROM is compatible with many HDA . So the ROM in the pcb must have matched with the hdd so it worked fine .
Users browsing this forum: No registered users and 291 guests
