 Post subject: Is there a way to manually create PLIST for N40P
PostPosted: September 4th, 2004, 16:59
Have here N40P with P defects output from 33h which seems OK.
plist 18h is corrupted - FE FF FF FF 00 00 00 00.
plist copies are also corrupted.
I want to try to edit 18h plist from listing : CHS and length.
can this be done manually ?
 Post subject: Re: Is there a way to manually create PLIST for N40P
PostPosted: September 5th, 2004, 2:32
deleted
PostPosted: September 6th, 2004, 5:59
Yes of course. But you must know how to recalculate CRC of this module.
If you talked about AT_PDL - yes, it can be done manually.
1. This is more quick then use "other" method ;)
2. This is not a big challenges.
2Diogen: PC3k can fix CRC :)
best regards, vi, http://pchdd.narod.ru
PostPosted: September 6th, 2004, 14:46
Sometimes I don't trust these click programs, especially the regen.
Ah any help with structure of AT_PDL to manually edit it - I will be grateful.
Also offset 84h in Disk module - how to establish this when this module and the copy are BAD!
soory for the many questions
Users browsing this forum: No registered users and 102 guests
