 Post subject: platters swap
PostPosted: September 1st, 2004, 2:28
Hi there,
I am a new user but I've recently spent here a lot of time. And in HDD subject I am also no newbie.
Now I am preparing to operation "platters swap". I built at home clean box and then... realized that I have no idea how to swap 2 platters without changing even a little their orientation one to another. Heads are combined so cylinders on platter no1 and no2 are always the same but if I move one platter few degrees sectors will differ from the original state and will not mach the original state before swap.
Can anyone give me some clue if it is possible to succesfully swap more than one platter disks? What about tools? Any info will be helpful!
regards
Stars
 Post subject:
PostPosted: September 2nd, 2004, 0:36
The best tool is to swap the head stack only and do not touch the platters ;)
-BR-
 Post subject:
PostPosted: September 2nd, 2004, 2:33
Heh - that didn't came to my mind :) Not a bad idea. Will it help with klicking heads problem?
regards
Stars
 Post subject: re
PostPosted: September 2nd, 2004, 3:22
What model of hard ?
 Post subject:
PostPosted: September 2nd, 2004, 4:53
Now WD AC26400, but the question was in general about the whole idea of platters swap. Has anyone instead of swaping platters swaped head stack? I suppose it shoul be exact same head stack (eg. disk model, but also same head manufacturer - same drives came with heads made in different places).
 Post subject:
PostPosted: September 2nd, 2004, 7:03
All the people swap head stack ;) except slim hdd models, where really better to swap platter.
 Post subject:
PostPosted: September 2nd, 2004, 23:58
Totally agreed. Platter swap have two major problems:
Centering and de-alignment (the last for drives with two or more platters).
-BR-
 Post subject:
PostPosted: September 3rd, 2004, 4:32
After swapping head stack no head realigment is necessary is suppose - its all done by drive itself after spin up - am i right? Any other usefull tpis? ;]
regards
Stars
Users browsing this forum: No registered users and 102 guests
