 Post subject: Maxtor 6L200P00 Rztbl-Hlist error
PostPosted: May 14th, 2007, 4:22
Hi guys
i have Maxtor Maxtor 6L200P00 , SA Structure test with the following results:
Any idea what is wrong? Translator? Regenerate translator half way got error techno mode command error.
Thank's
Checking RZTbl-HList
Beg.Cyl. End Cyl. :Def.count Def.count (PList)
1082 - 1295 :4064 / 4096
63928 - 64207 :0 / 3
64768 - 65047 :0 / 2
65048 - 65327 :0 / 1
65888 - 65932 :0 / 1
66818 - 67112 :0 / 1
67113 - 67407 :0 / 42
67408 - 67702 :0 / 1
70653 - 70947 :0 / 7
70948 - 71242 :0 / 1
71243 - 71537 :0 / 1
71538 - 71832 :0 / 2
71833 - 72127 :0 / 2
73034 - 73341 :0 / 1
73342 - 73649 :0 / 1
73650 - 73957 :0 / 1
75190 - 75497 :0 / 11
75498 - 75805 :0 / 41
75806 - 76113 :0 / 3
76422 - 76729 :0 / 42
77346 - 77653 :0 / 2
77962 - 78269 :0 / 3
78903 - 79228 :0 / 42
79229 - 79554 :0 / 3
80207 - 80532 :0 / 1
80533 - 80858 :0 / 1
81511 - 81836 :0 / 3
82163 - 82488 :0 / 44
82489 - 82814 :0 / 374
83793 - 84118 :0 / 3
84119 - 84444 :0 / 113
84771 - 85096 :0 / 1
85097 - 85387 :0 / 42
85744 - 86099 :0 / 2
86100 - 86455 :0 / 462
86812 - 87167 :0 / 2
88592 - 88947 :0 / 1
89304 - 89659 :0 / 42
89660 - 90015 :0 / 15
90016 - 90371 :0 / 31
90372 - 90727 :0 / 44
90728 - 91083 :0 / 1
92251 - 92628 :0 / 43
92629 - 93006 :0 / 35
93763 - 94140 :0 / 2
94519 - 94896 :0 / 3
94897 - 95274 :0 / 1
95653 - 96030 :0 / 5
97165 - 97542 :0 / 1
97543 - 97920 :0 / 1
97921 - 98298 :0 / 42
98358 - 98764 :0 / 1
100393 - 100799 :0 / 1
100800 - 101206 :0 / 46
101207 - 101613 :0 / 3
102835 - 103241 :0 / 50
103649 - 104055 :0 / 1
 Post subject:
PostPosted: May 15th, 2007, 21:34
Hi Jose any bads in SA? I have some diamond max9 with bads in RZTBL do the same thing
I think ST is a sub company of Lucas
 Post subject:
PostPosted: May 16th, 2007, 0:15
SA Surface verification has no errors
SA structure test All modules are ok except RZTBL-Hlist errors.
strange....hope someone know what is wrong :roll:
 Post subject:
PostPosted: May 16th, 2007, 22:09
Did you try surface scan, add defects to P-list, regen translator, just in case someone has messed with drive before? I had similar errors before but they were for all maxtors (Techno command unexpected error, in this case was hardware related, I had to change motherboard to fix it)
 Post subject:
PostPosted: May 16th, 2007, 23:03
Checking module 33, if you only need to repair HDD, do "clear all table" command after rewrite the module. SA structure test done with all modules OK not mean the code inside the modules is good. Open the module you want to check-select some line and do the "checksum" command.
 Post subject:
PostPosted: May 17th, 2007, 0:58
hi guys....surface test for physical test failed in certain CHS (errors in AMN).
Module #33 is ok..data is important....i m trying to scan for physical defect and add to glist and regenerate translator to see how it goes.
 Post subject:
PostPosted: May 17th, 2007, 5:50
Can you open defect list PLIST-GLIST and save it as a file?
 Post subject:
PostPosted: May 17th, 2007, 20:57
hddlab, Plist and Glist can be recorded and saved, but Glist have all false candidate which i dont know what it means.
Glist
Init : LBA 0
Fin : LBA 0
Num : 1
RLBA : 0
Candidate : False
 Post subject:
PostPosted: May 17th, 2007, 22:45
That's look like you just find out your answer, Jose Pinto. Try to back up all modules, rewrite GLIST and run Regenerate Translator command.
Users browsing this forum: No registered users and 61 guests
cron
