 Post subject: ST160812AS dam Slow need data
PostPosted: May 20th, 2007, 5:14
Hello to all
I have received Seagate 160 GB Hdd
ST3160812AS SATA hard disk. which detects ok but is very slow. When I try to clone it copies 1 sector in 5-7 Second. When I see its termainal Report it gives.
Interface task reset
4096k x 16 SDRAM
TONKA2 - 1_Disk M-31 11-15-05 14:51
Head Mask FFFF - Switch to full int.
Spin Ready
(P)SATA Reset
AT Er 00 Nwt Er 43 RdWr 0f57d.00.0000
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 97f29ff7 b6 97f29ff7.1.6b4 0000 005f 0000 0001
CE Log ErrCode=43 LBA=9c339fc Type=4 Remove from Pending 9c339fc
AT Er 00 Nwt Er 43 RdWr 0f57d.00.010e
Niwot: 9ff79ff7 b6 9ff79ff7.1.6b4 0000 005f 0000 0001
DiskAccess ReadSector EC=43 at 00f57d.00.010e
CE Log ErrCode=43 LBA=9c33b0a Type=5 Add To Pending 9c33b0a
AT Er 00 Nwt Er 43 RdWr 0f57d.00.010f
DiskAccess ReadSector EC=43 at 00f57d.00.010f
CE Log ErrCode=43 LBA=9c33b0b Type=5 Add To Pending 9c33b0b
AT Er 00 Nwt Er 43 RdWr 0f57d.00.0110
although Er 43 means Data ECC Error. When I check Smart. it give BAD. What could be done to make it work fast and recover data.
Thanks and Regards
DF
 Post subject:
PostPosted: May 21st, 2007, 0:50
any suggestion
DF
 Post subject: Bad head
PostPosted: May 21st, 2007, 22:47
perhaps a bad head wich need to exchange it with a donnor MHA
Users browsing this forum: No registered users and 63 guests
cron
