 Post subject: Which chip holds the firmware? Calipso III
PostPosted: May 21st, 2007, 13:39
This hard drive has a burnt smooth chip. I found an almost identical PCB but it didn't work. My question is is it better to pay someone $100 to swap out the smooth chip or can I swap out the Firmware chip myself. I believe its one of the 3 8 pin ic's but i don't know which one it is. Thanks, Ben
PostPosted: May 21st, 2007, 14:44
Rom IC is 25P10V on top right (U401)
PostPosted: May 22nd, 2007, 6:24
Change only that IC
and must work!!!
PostPosted: May 22nd, 2007, 7:31
It should work without resoldering
Something else has been broken
PostPosted: May 22nd, 2007, 11:44
What happens after swapping the PCB?
Does it ID? If yes, how? Do you get any clicking?
 Post subject: when powered on
PostPosted: May 22nd, 2007, 14:35
When I power it on it does not register in the BIOS and it clicks once.
 Post subject: It worked
PostPosted: May 22nd, 2007, 19:38
I swapped the chip and it worked. If any one els tries this a tip is to cut the chips off with a razor blade instead of trying to desolder them.
thanks for your help, Ben.
PostPosted: May 23rd, 2007, 2:51
there is no problem with desoldering the ICs, cutting sucks :)
though I'm glad U succeeded.
PostPosted: May 25th, 2007, 3:27
Even if u tried resoldering the SMOOTH chip u wouldnt have suceeded because the prints are burned .
Users browsing this forum: ccc and 90 guests
