 Post subject: 40gig Maxtor show only 10mb
PostPosted: May 21st, 2007, 2:12
I have a Maxtor 40 gig, a 6E040L0711014 to be exact. I had it in an XBOX and had to lock it. I have removed it and unlocked it with the correct key. It will now only show as a 10mb drive, LBA 19999. I have search everything and have come up with not solution, other then flashing the firmware with the hopes it would reset the LBA and recognize it as a 40 gig drive.
Anyone have any idea?
 Post subject:
PostPosted: May 21st, 2007, 2:48
Check the HPA function first, before do anything to drive firmware.
You can use MHDD for that.
DataRecovery.bg
 Post subject:
PostPosted: May 21st, 2007, 3:02
I tried that...no luck. It only shows LBA 20000 total.
Thanks for the suggestion
 Post subject:
PostPosted: May 25th, 2007, 3:10
u will have to rewrite 1F module using pc3k or any other tool that could rewrite fw .
 Post subject:
PostPosted: May 25th, 2007, 8:33
Hi also check xboxscene, they had a flasher for a 20gig seagate that was standalone software, also check the forums there was another post a couple of weeks ago about a locked maxtor xbox drive.
I think ST is a sub company of Lucas
Users browsing this forum: No registered users and 60 guests
cron
