SP0802N REV D
May 23rd, 2007, 15:39
HI TO ALL.
MHDD REPORT FOR HDD
F8 OK
F2 OK
F4= SCAN ERRORS
AAAAAAAA (LBA 0) LBA 63) many errors!!!
IT HAS REGIONS IN THE HDD THAT GOOD
EXAMPLE: LBA 73 100 000 EVEN 79 343 000
What I CAN MAKE TO RECOVERY The DATA?
Problem SA? :?:
thanks for helps..
May 23rd, 2007, 22:28
I would try to read the good sectors to another hdd (previously zeroed) and then run some recovery software in raw mode to recover the files. I have used ddrescue (available in the boot cd RIP linux) to do that with good results. That's just my 2 cents, I'm not an expert. I'm sure someone with more knowledge could give you better advice.
May 24th, 2007, 0:21
There is a problem with this model. it suddenly became like this. It is very difficult to recover data from this hard disk.
DF
May 24th, 2007, 2:38
The problem is probably with one head. Check the periodicity of the bad/good areas, if it is ~3000000 LBAs, it is surely head problem.
It can even be that in the beginning there is a larger area, but it can be head problem even then.
regards,
