 Post subject: 1Gb USB Flash drive seen as Zero bytes
PostPosted: May 18th, 2007, 15:45
Hi!
Any suggestions on how to get data from a USB flash drive that is picked up in XP, but as 0 bytes?
DE, GetDataBack etc cannot see the drive at all.
Cheers
 Post subject:
PostPosted: May 18th, 2007, 23:13
Check connections are clean, I had one with the same problem USB contacts were dirty.Winhex may be able to read also.
I think ST is a sub company of Lucas
 Post subject:
PostPosted: May 21st, 2007, 8:57
Hi, thanks for reply.
However:
1. Connections are clean
2. WinHex can only see logical (and will not open "The Parameter is incorrect" and "Unsupported sector size" and |"Cannot access drive G:"
Cannot see it as physical size.
Any other ideas guys?
Cheers
 Post subject:
PostPosted: May 21st, 2007, 9:22
It's OK, found the problem.
Opened up the stick and found some loose connection on the flash RAM chip.
Fixed them then now see data 100% :-)
Thanks anyway!
 Post subject:
PostPosted: May 28th, 2007, 2:36
oh~~it's interesting.
SalvationDATA--Profesionnal Hard drive solution Provider. MSN: sales.laura@salvationdata.com
Users browsing this forum: No registered users and 60 guests
cron
