 Post subject: Main Board
PostPosted: May 25th, 2007, 11:49
Does anyone know of a good place to buy replacement boards for hard disks?
I am currentlylooking for a Maxtor Draco II 301283100
PostPosted: May 27th, 2007, 4:55
The best place would be this forum if someone would have he would contact u .
PostPosted: May 27th, 2007, 10:02
What is model of drive?
PostPosted: May 31st, 2007, 11:34
It is a Maxtor 52049U4 20GB
The codes on the front of the drive give the following info:
HDA = 04A
PCBA = 03A
Unique = 24A
Code = DA620CQ0
PostPosted: May 31st, 2007, 12:04
Ok, I have some 52049U4 PCB's.
What's the 5 digit ROM code from the little white label on the PCB (e.g. A4DKB)
PostPosted: June 1st, 2007, 3:36
yes also tell me i also have many of these drives .
PostPosted: June 15th, 2007, 17:58
Sorry, but I have not been on line for a while..
Right, the code on (the one on the large square chip on the PCB) is A3DKP3. It was this main chip that was damaged... :(
I was told 2 days ago in a discussion with a company that does this kind of thing that I need to match 3 specific codes on a similar drive, these are as follows:
HDA = 04A
PCBA = 03A
Unique = 24A
Also, the main code on the PCB (the specific one under where it says Maxtor Draco II) is 301283100.
I am wondering if by matching this I will find a PCB that was made at the same time, and therefore hopefully be near enough identical.
Thanks for you help
PostPosted: June 16th, 2007, 9:06
BTW what was the initial problem with the drive?
PostPosted: June 17th, 2007, 13:23
if the pcb is dead it would be better if u would repair the pcb , because this pcb is really hard to find .
 Post subject: Re: Main Board
PostPosted: July 18th, 2007, 5:07
unfortunately the main PCB in the centre of the board is damaged, I seriously doubt I could remove and replace it :(
PostPosted: July 18th, 2007, 5:37
You can always try here: http://stores.benl.ebay.be/Marcs-Vintage-Electronics
I add drives on a regular basis.
For the moment this drive is not in the store, but that can change quickly ;)
Regards,
Dobre
Murphy was an optimist
PostPosted: July 21st, 2007, 0:14
I have that drive. I was just helping a friend and we rummaging through my box of old drives. I looked this one up to see how big it is :)
Anyway, on the circuit board it says
Maxtor
DRACO II
301283100
Are you still interested in it?
