 Post subject: maxtor pcb
PostPosted: May 29th, 2007, 5:55
i have one maxtor plus 9 80 gb drive clayspo III itis pcb didnot power up i try to change power ic without change happen so where is problem?
and i replace pcb pcb by of 80 gb by pcb 60 gb it has 3 8 pin ics on it hte drive power up but clicking so it cannot compatible with this drive?
DMS
PostPosted: June 1st, 2007, 3:25
u should also change the ROM chip along with pcb.
PostPosted: June 1st, 2007, 11:17
rameez, stop advising bullshit, please. :?
PostPosted: June 1st, 2007, 11:44
Not many of these drives have a ROM, so 60/80/120Gb does not matter.
If original has no ROM, and you get clicking then you have FW issue or failed head(s)
PostPosted: June 3rd, 2007, 5:00
What is the bullshit that i advised , if there was something wrong i said u should have some manners to tell it to me .
PostPosted: June 3rd, 2007, 8:58
rameez ,
when you talk about change the ROM:
- It is right only for :
pcb versions: E4FYA , E4FYB and G6FYA !!!
All of them have ROM and version of that ROM
depends on version FW of HDD.:
YAR41VW0 or YAR41BW0....
IN that case if you excnange pcb's between different
FW version of HDD you must change ROM......
The other versions: F4FYA ,K2FYA , M6FYA have not the ROM !!!!!
PostPosted: June 8th, 2007, 3:02
yes u r right gsimon i advised this because i didnot know the pcb no .
Users browsing this forum: No registered users and 46 guests
