 Post subject: MAxtor Problem
PostPosted: May 31st, 2007, 10:19
MAxtor Problem i have one maxtor plus 9 80gb drive clayspo III itis pcb didnot power up i try to change power ic without change happen so where is problem?
and i place defeat pcb by another pcb from same model but it for 60Gb and pcb have 3 8pin ics and the main have 2 pin ics so how i know problem in main pcb or how to make pcb of 60gb work on 80gb
Dms_Corp
PostPosted: May 31st, 2007, 12:25
Size does not matter on these. I've used PCB's from 80Gb models to work perfectly on 160Gb models.
If the original PCB did not have a ROM at U401, then any PCB without ROM from same family will work.
If original has ROM, then u need board with ROM and move original ROM across.
PostPosted: June 1st, 2007, 2:27
there is a fusible resistor on calypso III boards that usualy burns when the motor controller fails. It is located besides R504, but a smaller one.
U should also check Q500, this is often shorted when the L7250 burns, and if so, the new one will be gone soon.
regards,
