 Post subject: Toshiba Rotor Problem Help!!
PostPosted: August 16th, 2007, 14:05
Hello Every one. i have a Toshiba Hard Disk, whit Rotor Problem. it is posible Fix it? jus for DR.
the rotor its not working, the PCB is working Fine.
 Post subject: Re: Toshiba Rotor Problem Help!!
PostPosted: August 16th, 2007, 16:48
Have you tried swapping the board? Have you opened it? Will it spin manually?
PostPosted: August 16th, 2007, 16:58
rchadwick,
Actually i swap the board and the problem stil, i oppened and spin manualy, but when i connect the Drive the motor tray to spin but stops.
Thanks .
PostPosted: August 16th, 2007, 23:11
You can swap platters & heads to a drive with a good motor & bearing.
http://www.datasaversllc.com
PostPosted: August 17th, 2007, 5:05
Or you could heat the motor with a hot air gun to get the melt the liquid bearings that make the toshiba spindles faile :D
PostPosted: August 17th, 2007, 11:02
HI.. Thanks to all,, ill do and if works. ill keep it post the results.. thanks to all for youre support.
PostPosted: August 17th, 2007, 22:45
That technique never worked for me. Heat also causes the lubricant to contaminate the drive chamber. IMHO, motor replacement works best.
Jon
PostPosted: August 20th, 2007, 16:56
Jon
Thanks For youre Post..
Users browsing this forum: Google [Bot] and 115 guests
