 Post subject: How to get T-Level without motor-spinning.(Seagate terminal)
PostPosted: July 13th, 2007, 6:25
Thank you so much
 Post subject:
PostPosted: July 13th, 2007, 6:26
HOW can... ???
Impossible..
 Post subject:
PostPosted: July 13th, 2007, 8:30
From Level F to level T with disabling spin up.
Samuil
DataRecovery.bg
 Post subject:
PostPosted: July 13th, 2007, 14:18
hi drnoom
when readding ROM then spin down but i dont know whats you doing.
 Post subject:
PostPosted: July 13th, 2007, 17:58
Thanks for answers. I need to use the PCB and HSA of the drive for making media tester.
I would like to use only head and PCB of the drive to read/write data on a sample medium.
if I can go to level-7 then I can control the operation of preampfiler of HSA.
if anyone know the solution, pls give me some suggestions.
Thanks & best regards. :)
 Post subject: Re: How to get T-Level without motor-spinning.(Seagate terminal)
PostPosted: July 16th, 2007, 10:33
7>O0,1,1 ( Test head 0, zone 1, simplified form ) Zone 1
[0DCA.0,FDC0,FF6A,1c, 3] ->Min=023C(FE47) BL=7FFF BR=7FFF Range=0000 Pick=FE47
[0DCA.0,FDC0,FF6A, 1, 3] ->Min=000C(FE41) BL=FE23 BR=FE59 Range=0037 Pick=FE3E
This means that it ran the offset cal in zone 1 head 0. It ran the test at 0DCA.0, and it tested the offset range from
0xFDC0 – 0xFF6A. It read 0x1C revs at the track. It also incremented the offsets by 3 each tick. I.e. it tested offset
0xFDC0, then 0xFDC3, 0xFDC6 etc… The results are, in the first test, it got a Min of 0x23C at location 0xFE47. There was not bathtub curve (got a 0x7FFF for bath tub left, and bathtub right). Since there was no bath tub curve, the range is 0. The pick would be then the position where the min occurred as there is no bathtub curve.
As there was no bathtub curve, a retry was initiated, but with a lower read count. As you can see on the second line, we are testing the exact same parameters, except we are reading 1 rev instead of 0x1c revs. With that we have a bath tub curve, ranging from 0xFE23 to 0xFE59, hence giving us a range of 0037. We pick the center of the bathtub giv- ing us a 0xFE3E
:D
PostPosted: July 16th, 2007, 18:33
two options
1. load app to memory and start it (get levels)
2. manipulate with preamp on level F
Do not ask me how do that
What I didn't get - how you supposed to test heads on Zone1 w/o spinning ?
Users browsing this forum: Majestic-12 [Bot] and 74 guests
