 Post subject: capacity problem, external hd answer?
PostPosted: June 5th, 2007, 19:09
I will be using my laptop exclusively for quite a while (im moving for school) and require massive amounts of storage space, ideally 400GB. I have never seen a 1000$ with this kind of space. So is the answer an external HD? I will be using it for multimedia files, hi-res. Are the transfer rates on external drives capable of handling this? is firewire the way to go? usb seems too slow for this task. Can someone recommend a external HD and tell me if a external drive is the answer to my problem?
 Post subject:
PostPosted: June 5th, 2007, 20:07
So regualar size HD in the laptop, with DVDRW. But wont i burn out the DVD drive then? lol Thanks for the dvd idea though, i never really thought of it to be honnest. But thats alot of DVDs... :shock:
 Post subject:
PostPosted: June 6th, 2007, 9:44
You should definitely use external drive.
Hitachi just shipped 1TB external USB drive, that should be enough for you I guess :)
Users browsing this forum: No registered users and 53 guests
