 Post subject: maxtor diamondmax plus 9
PostPosted: June 7th, 2007, 0:00
I have a maxtor diamondmax plus 9 6y120L. It spins but, No recognition in bios or windows or any software. Sometimes the bios reads it as a maxtor calypso with 0gb 0sectors, etc.
Any suggestions, the data is valuable and yes this IS my backup. I have an identical drive in my comp now. is the easiest way to replace pcb with known good one?
I have also tried loading into knoppix, pclinux, No go. I also put the drive into usb enclosure. That didn't work.
 Post subject: Maxtor
PostPosted: June 7th, 2007, 0:22
This could be a SA problem, need to be analyzing by a Data recovery expert , or u need to have the right tools, and the knowledgment for do this task , could be dont repair changing PCB¨S
PostPosted: June 7th, 2007, 4:31
Yep, sounds like SA problem.
Need specialist tools.
Where are u based?
PostPosted: June 7th, 2007, 9:33
I am in western pa, I m pretty knowledgable in other computer repair areas. This isn't something I can try myself?
PostPosted: June 7th, 2007, 10:01
No, unfortunately it's not about knowledge only.
You will need tools to work with hard drive firmware like PC3000 affordable only to data recovery companies.
PostPosted: June 7th, 2007, 10:09
You sure should try swap the board first. There is a tiny chance it could help.
PostPosted: June 7th, 2007, 14:51
I only need the drive for a short period to get back one folder, the rest oh well can live without. Just can't see paying thousands of dollars to a data recovery service to get some home video back.
what is MHDD ? what does it do?
 Post subject: exact description of problem
PostPosted: June 7th, 2007, 21:28
About 6 months ago, I was transferring data to or from the drive (can't remember which). it starting clicking noise. I immediately shut down the computer and disconnected the drive. Thinking, when i get time i will grab the rest of the data off b4 it totally crashes. Last week I plugged drive in and I feel it spin up as it clicks (rather high pitched), but I get no recognition in bios, windows or any other software. So I put the drive in an external case I had to see if maybe...
I have tried different scenerios, as master, as slave several different regular data recovery software and methods (knoppix, magic recovery, spinrite, getdataback, dos) all to no avail.
I had a WD that clicked and wasn't recognized in bios or windows, I somehow got that to work with windows vista and the usb drive enclosure so I thought I would tinker with this maxtor.
Where does one purchase pc3000? How much is it? I have a computer repair business and wouldn't mind playing with just to see and learn more.
Thanks for any info.
