 Post subject: maxtor firmware
PostPosted: May 30th, 2007, 18:30
hi...i'm italian so sorry for my bad english...
i have a problem with a maxotr diamond plus 8 firmware 6E040LO
when the bios detect it says that i have n40p hard disk
i googled a lot...so i think that is a firmware problem...i know that i must to use pc-3000 to reflash the firmware
anyone can link to me an howto??
i have followed an italian howto(by a user in a forum) but i have a lot of problem
tnx!
 Post subject:
PostPosted: May 31st, 2007, 16:28
tnx for help..............
i want to know how i can set the safe mode...anyone says that the safe mode with jumper isn't be enough
he says that i need an external AT (not atx) power supply...
 Post subject:
PostPosted: June 1st, 2007, 3:40
who said that u should read the manual it will give u all the info u need .
 Post subject:
PostPosted: June 1st, 2007, 11:13
Safe mode is uselss without PC3000.
 Post subject:
PostPosted: June 4th, 2007, 6:02
i have chcked the manual...so
i set the jumper '_::
load an ldr file--rom and modules <---it's ok!!
when i go to standard mode and the drive is set up it give me an error with modules...but the model name became correct!!!after reboot the hard disk doesn't work
i also have tried with Modules repairing but doesn't works
help!
 Post subject:
PostPosted: June 4th, 2007, 11:11
Checking of disc FM structure doesn't tell me anything
SA surface checking:
DATA, COPY1 BAD
OVL COPY1 OK
SELF SCAN OK
SWAP1 OK
SWAP2 BAD
DEFECTLOG OK
DATA COPY2 BAD
OVL COPY2 OK
... OK
... OK
how can i know wich module i must to write to SA?
 Post subject:
PostPosted: June 4th, 2007, 11:22
One of the modules in DATA COPY2 modules group is bad. To know which one precisely you need to check modules, not modules groups.
 Post subject:
PostPosted: June 4th, 2007, 12:08
i'm sorry i'm noob
how?
and data copy1?and swap2?
 Post subject:
PostPosted: June 4th, 2007, 13:44
i have downloaded it from net (with .ldr file)
but i don't know in practice how i can check the modules
mayby i must type "Reading of modules"?mark all modules and try to read?
i have done this...all modules give me an error
 Post subject:
PostPosted: June 4th, 2007, 18:45
so...i'm tring to understand
copy1 uba=$0008 size=$04bo
uba=8 uba=164-190 error 04h
swpa2 uba=$45ao size=$0190
uba=18123-18130 error 04h
copy2 uba=$48c6 size=$04bo
uba=18630 uba=18786-18812 error 04h
not sure that error is o4h for all...tomorrow i check it (in italy now it's 0.42 am) good night :wink:
 Post subject:
PostPosted: June 5th, 2007, 6:58
now i can see the report of fw structure
how can i understand what modules are damaged?
maybe i must check the column rd??i must to write the modules with "-"?
 Post subject:
PostPosted: June 5th, 2007, 13:28
i don't know why :D :D :D but now bios show the hard disk correctly...but doesn't seems to be all good now
boot from hard disk interrupt at the middle (debian gnu/linux ext3)
i'm tring to see the partition from another hard disk...the partition table is ok!!but i don't be able to read the data inside the most important partition for me
any suggest?
 Post subject:
PostPosted: June 8th, 2007, 7:39
well, to be honest, I don't think that your problem is solved yet. You need to execute "read Modules" command using PC 3000. This will create several .rpm file in the root directory of PC 3000 (I'm assuming you're using the ISA version).
In the created directory [MXPKRMOD], you will see inside the folder several files named .bad. These are the modules you must replace with the good ones taken from a functional drive. But be very careful, You should not overwrite modules which controls the "adaptive settings" (Class A modules)
After you find the correct modules for replacement (and you know which ones to write and which are not to write), you can execute the write modules command using PC 3000 Maxtor Poker Utility again.
After you have written them, you should do the SA Testing again and make sure everything is OK.
Good Luck...
 Post subject:
PostPosted: June 10th, 2007, 11:54
u can use the SA structure test to check for bad modules it gives u a whole log report if u are not able to understand it u can post the log here .
U can save the log report using F2.
Users browsing this forum: No registered users and 92 guests
