 Post subject: Spindle motor Jam on WD SCORPIO 2.5 INCH HDD
PostPosted: June 9th, 2007, 6:02
HELP REQUIRED TO RETRIVE DATA
i HAVE A WD SCORPIO 120 GB WD1200UE-22KVT0 WITH A MOTOR JAM PROBLEM. THE HDD IS NOT ABLE TO SPIN. I SWAPPED WITH A DONOR PCB MODEL WD1200UE-00KVT0 BUT THE PROBLEM REMAINS THE SAME. I HAVE CONFORMED THAT CARD IS OK. CAN ANYONE SPECIFY HOW WE CAN SOLVE THIS PROBLEM.
 Post subject:
PostPosted: June 9th, 2007, 6:15
Check for stiction first.
More likely than motor jam.
 Post subject:
PostPosted: June 10th, 2007, 6:07
Agree. The simplest way to make sure about this is to open the HDA cover in the clean room, and see what's going on inside.
 Post subject:
PostPosted: June 10th, 2007, 6:19
Yep, make sure it's in a proper cleanroom. Or you can make the problem a whold lot worse!
If you're in UK, I'll do it for you.
Users browsing this forum: No registered users and 60 guests
cron
