 Post subject: Seagate ST340015A 3.01 problem
PostPosted: June 19th, 2007, 4:58
Hello to all
I have a Seagate hard disk ST3410015A 3.01 When plugged give this report in terminal. And after 2-3 min it detects itself as STXXXXXXX Firmware 1.1.01 Serial 3xxxxxxx and capacity and every time terminal report is diffrent. I tried Hot Swap but no success. is it head problem.
----------------- 1 try terminal report ----------------------------
Interface task reset
Hd Msk 0A00 - Switch to full int.
Ready
C2 - ST340015A(S) Grand 2A3, Head 12
ROM.02.03
$Hd Msk 0800 - Switch to full int.
Ready
Ready
Ready
Ready
------------------------END------------------------
---------------------Try 2 terminal report--------------------
Ready
ROM.02.03
Ready
Key 06h Err!
Ready
Key 02h Err!
ROM.Mstr
need data. should i replace head. Needed your guidance
Thank you
DF
PostPosted: June 19th, 2007, 8:01
Hey buddy
This is the most common problem with those f***ing slim drives. And it is cause of the bad head. No any f/w level tool or software can help you in this case, as you need the data. so, in this case, you can try these two things one after one:
1. The tapping method (Really, It does revives those slim drives often....)
2. Head Swap (Though, it should be your last try, as there is high risk that you would screw up the drive's remaining stability !)
If you need help, you can contact me personally, as you know my yahoo ID.
harddiskbug@yahoo.com
PostPosted: June 20th, 2007, 14:20
switching heads in these drives is really hard is there head assembly is different from common seagate drives , so be careful .
 Post subject: Re: Seagate ST340015A 3.01 problem
PostPosted: August 27th, 2009, 17:11
darkforce1 did you fine solution to your st340015a drive im asking because
mine has problem of firmware corruption
Users browsing this forum: Google [Bot], runner978 and 159 guests
