 Post subject: Password Protected HDD IBM Travelstar Model DBCA-206480
PostPosted: June 21st, 2007, 15:40
Any Kind Of Assistance With ISA /PCI or Any Tools Would Be Appreciated .Anyway Still Just Trying It
 Post subject:
PostPosted: June 21st, 2007, 16:44
No Mention of this In Manual ,Can Someone Help Me
 Post subject:
PostPosted: June 25th, 2007, 1:11
Hi Guys,
Even 2.27 Does Not Have Support for This Drive Can Someone Tell Me How To Remove the Security Password ,Data Is Not Imp In this Drive Just Repair Is Wanted
 Post subject:
PostPosted: June 25th, 2007, 9:13
try hot swap
wwalab
 Post subject:
PostPosted: June 25th, 2007, 10:30
hot swap.
 Post subject:
PostPosted: June 25th, 2007, 23:23
Mate,
Ho Swap For Password Removal ? .Pepe Jump In And Help Me Mate .Any Idea's [ No Data Is Required ]
 Post subject:
PostPosted: June 26th, 2007, 13:29
yes hot swap works for password removal .
 Post subject:
PostPosted: June 26th, 2007, 14:21
Hi Guys,
What Is The Use of Such a Good Forum If You Guys Are Not Gonna Help .I Always Try My Best To Help My Fellow Mates I Am Getting Desperate Not
 Post subject:
PostPosted: June 26th, 2007, 15:36
Correct me if I'm wrong...
1. Start good drive, same as original
2. Stop motor
3. Swap HDA while original PCB connected
4. Start motor
5. Set P/W (and remember it)
6. Power down.
7. Now you know new P/W, so easy to remove!
But.........I guess you don't have donor, so job is nearly impossible as PC3000 has no support for this drive :-(
 Post subject:
PostPosted: June 28th, 2007, 12:44
Hi PCIimage ,
Exactly ,I Do Not Have a Donor .But i Will Check If i Can Find One .Do We Need To Worry About Other Formalities or Just Get The Same Model HDD
 Post subject:
PostPosted: June 28th, 2007, 14:21
Also match the PCB # (as u know what to match) :wink:
DF
 Post subject:
PostPosted: June 28th, 2007, 15:34
To check compatability, test the patient PCB on the donor, it should still work perfectly with either board
Users browsing this forum: Google [Bot] and 74 guests
