 Post subject: Maxtor loader required, thanks!
PostPosted: June 29th, 2007, 9:20
Hi all!
I need a loader for a Maxtor Sabre drive:
6B200P0
BAH41BYO
Anybody have?
Cheers
Sean
 Post subject:
PostPosted: July 2nd, 2007, 7:48
Nobody have?
 Post subject:
PostPosted: July 2nd, 2007, 21:59
why you need loader friend.
only UDMA support to load loader in maxtor Sabre.
if you dont have UDMA then you can not load loader from safe mode in MAXTOR SABRE..
HMMMM I think you got mistype. it is 6L instead of 6B
Aping
 Post subject:
PostPosted: July 3rd, 2007, 4:57
This is Sabre 1 drive, not Sabre 2.
Sure there is no support for Sabre in non-UDMA?
When put in Safe Mode, finds as Sabre and gives option to load loader.
Or am I missing something?
Cheers
Sean
 Post subject:
PostPosted: July 3rd, 2007, 13:02
It is supported. But you have to start firmware first, after that run ID and code should change. Then load the overlays in reverse order.
This should work.
Regards,
Dobre
 Post subject:
PostPosted: July 3rd, 2007, 15:12
Dobre,
Thanks for suggestion, will try "IF" I can source loader. :-)
I experimented with an good 80Gb Sabre drive, I was able to create and use loader.
Sean
 Post subject:
PostPosted: July 3rd, 2007, 23:54
Good advice ..
Thanks friend...
Users browsing this forum: arvika and 63 guests
