 Post subject: Tables within SQL Database
PostPosted: July 7th, 2007, 4:11
is there a tool that one can use to recover tables that have been deleted on a database inside an sql database file?
i had a client ask me if its possible and am not sure
GEORGE NJOROGE
EAST AFRICAN DATA HANDLERS LTD
http://WWW.datarecovery.co.ke
Chiromo court chiromo road, Westlands
Nairobi Kenya
+254-20-3751400/2/7
PostPosted: July 8th, 2007, 13:59
Has the user ever made a full, incremental or differential backup; and have they kept the logs? Maybe possible to replay partials logs against a previous backup.
It very much depends on the physical file layout on the disk, if recovery is possible; as it won't just be a single table that is affected by a "DROP TABLE XYZ" command. There's all the system objects and stuff.
scegs
