 Post subject: why hdd locked suddenly without someone lock it
PostPosted: July 19th, 2007, 17:49
salam alekm hello why any type of hdd suddenly locked plz i want explain to lock and how to unlock in steps
 Post subject: Re: why hdd locked suddenly without someone lock it
PostPosted: July 19th, 2007, 18:46
Bit vague!
U need PC3000 my friend.
PostPosted: July 19th, 2007, 22:57
salam alekm
why hdd locked suddenly without someone lock it and i have pc3k plz what to do
PostPosted: July 20th, 2007, 0:04
Have you tried unlocking it with your PC3000? What kind of drive? How do you know it's locked.
If you want help, you'll have to supply a lot more details.
PostPosted: July 20th, 2007, 11:36
salam alekm tests of heads gives errors in head 3 and 5 the hdd is locked with master password its wd 1600guc0 when i make unlock with pc3k gives error message freeze locked
PostPosted: July 26th, 2007, 4:35
Dear Friend, what brand of your hard disk? use SalvationDATA products.
SalvationDATA--Profesionnal Hard drive solution Provider. MSN: sales.laura@salvationdata.com
PostPosted: July 26th, 2007, 12:51
just reset pwd using Pc3k .
PostPosted: July 26th, 2007, 15:16
Could also try HDDRock - had some success recently.
scegs
PostPosted: July 28th, 2007, 12:37
whats hdd rock ?
PostPosted: July 28th, 2007, 20:03
I've heard of it recently. Is it any good? Can you actually brute force most drives quickly?
PostPosted: July 29th, 2007, 12:46
If the drive's on the Supported Drive List, yes, it'll unlock very quickly.
If it's not on the list, you can create a custom word and/or character set to try and brute-force the password. That will obviously take much longer :|
PostPosted: July 29th, 2007, 15:50
Like any tool, HDDRock should be part of an arsenal of weapons. There is a supported list (as with any tool) to make some actions easier, but brute force is often theonly way insome cases.
scegs
PostPosted: July 30th, 2007, 14:10
bruteforce with 32 characters would take a month .
PostPosted: July 30th, 2007, 14:17
what about disk freezing. after limited numbers of try.
DF
DF :)
www.datatracksystem.net
PostPosted: July 30th, 2007, 14:34
DF
:shock:
PostPosted: July 30th, 2007, 16:05
AFAIK after 3 bad tries the drive needs a power cycle. This will make the process take an eternity :)
PostPosted: July 31st, 2007, 19:18
pepe, a correction: after 5 bad times hard drive needs a hardware reset (or a power cycle, which is much longer but not really needed in this situation)
Dmitry
PostPosted: July 31st, 2007, 19:50
thanx Maysoft. It was about 4 years ago I dealt with this question last time. That's why I wrote AFAIK :)
PostPosted: August 1st, 2007, 6:50
Ok I too acknowledge
DF :)
DF :)
PostPosted: August 5th, 2007, 14:01
:lol: :lol: :lol: Hilarious :lol: :lol: :lol:
Guess WD Master PSWD is still "WDWDWDWDWDWD" >32bytes
A man is as old as he feels, and a woman as old as she looks
Users browsing this forum: Majestic-12 [Bot] and 77 guests
