 Post subject: Need compatible head info for WD2000
PostPosted: July 23rd, 2007, 14:25
Drive is WD2000JD-22HBC0
DCM: HSCHCTJAA
What and how much do I have to match for a head swap?
 Post subject: Re: Need compatible head info for WD2000
PostPosted: July 23rd, 2007, 15:24
T- Headstack
J- Actuator-Preamp
wawalab
good luck
PostPosted: July 23rd, 2007, 17:03
also check head map in ROM, should the drive have disabled heads U might get surprised also.
regards,
PostPosted: July 24th, 2007, 3:15
Pepe,
Thats Info Is Usually Skipped Mostly ?
PostPosted: July 24th, 2007, 11:39
I encountered that problem already Amarbir.
Some drives with equal partnumber and dcm can have different disabled/missing heads.
If a different head is disabled, the drive will start clicking; if a different head is missing, a head transplant will not work ;)
Regards,
Dobre
Murphy was an optimist
Users browsing this forum: arvika and 68 guests
