 Post subject: Help with DE
PostPosted: July 28th, 2007, 13:38
Hi to you all ;-)
I need to get 3 documents out of a drive, the one marked in red on the picture.
The only place I can even see these documents are in DE...I have tryed GDB with no luck.
When I try to copy them from DE I only get a error, because there is no start and offset I'll think.
Is there any way to retrive those documents, any input is most welcome.
[img]
Best Regards
Bosse
http://www.rescue-it.se
 Post subject: Re: Help with DE
PostPosted: July 28th, 2007, 15:00
Try Winhex.
DF :)
DF :)
www.datatracksystem.net
PostPosted: July 28th, 2007, 17:00
I would advise you find documentation on structure of NTFS (here for example: http://downloads.sourceforge.net/linux- ... g_mirror=1) and see what's wrong with those MFT records you are trying to work with.
PostPosted: July 29th, 2007, 16:06
Deleted files or corrupt $MFT!!!
$MFT sector results look interesting!!! Winhex would be a good starting point. Alternatively the post-ceding word files may have remnants or even "track changes" feature built-in, avoiding the need to recover?
scegs
PostPosted: July 29th, 2007, 19:58
Thanks for your replys.
I found the files in Winhex, but as i'm a total newbee on that progam I need some help and guidens.
What would be the next action?
[img][/img]
Best Regards
Bosse
Users browsing this forum: Google [Bot] and 74 guests
