 Post subject: Western Digital WD5000KS-00MNB0
PostPosted: July 27th, 2007, 13:34
Hey Guys
Anyone here in the USA had experience with this drive .
it was working then just stopped beinig recognised by bios
It doesn't ID
I sent it off to another DR company for repair and after a month
they couldn't get anything from drive ..
being that this is a fairly new 500 gig drive I have to assume
that it is firmware problems, and no-one has reversed it yet ..
the reason I beleive this , is that if it was just heads etc ,
my partner company would have repaired it in a few days.
My customer needs the data back.
Any help greatly appreciated
Steve
 Post subject: Re: Western Digital WD5000KS-00MNB0
PostPosted: July 28th, 2007, 11:15
Does it spin up?
Any clicking sound?
What company did you send it to?
This drive is supported by PC3000 UDMA. But it's fairly new tool and only 5 or 6 companies in US have it ;)
PostPosted: July 28th, 2007, 12:32
the drive spins up and clicks
says BSY
Does not ID
Not seen in bios
PostPosted: July 28th, 2007, 16:53
Then it has a problem with heads.
Did they open the drive and try to swap heads?
PostPosted: July 28th, 2007, 17:32
yes they opened the drive ..
logic tells me that if it was ONLY a head problem they would have been able to fix it .
They have PC3000 but not sure if they have UDMA
what I am really looking for is someone that recover this data
sure I would like to know what the problem is , but in all reality
Customer just needs Data .
I really don't want to name the company but they are listed as a customer of Deepstar ;)
I need a company that isn't gonna penalize me because another company opened the drive ( they are allowed by the drive manufacturers)
I have been pleased with their work in the past , as I send them work anytime I feel there is a need for clean room
PostPosted: November 14th, 2007, 5:23
I also have one of these disks, My disk reaches DSC and DRD but doesnt ID and capacity is 0. I have replaced PCB and disk stays BSY, after a ROM swap it behaves the same as before. It doesnt click at all.
I dont have much experience with these new WD disks.
PostPosted: November 14th, 2007, 5:56
Steve,
You should ask that DR company if they tried to disable or swapped heads so you can understand what they did until now.
Users browsing this forum: No registered users and 80 guests
