 Post subject: Disabling Samsung HDD Head ?---> How To
PostPosted: August 7th, 2007, 16:15
Today i got a SV4002H .I checked the SA Area And Found Out the Slist And Elog Have a Reading Problem on Head 0 But Head 1 Reads Fine .the Issue i Have is that if i write from Head 1 To 0 I Still Get Read Error on Head 0 .What Are My options Can i Disable Head 0 And Make it 20 GB ? .PCI 3k Cannot disable Heads for Samsung .
 Post subject: Re: Disabling Samsung HDD Head ?---> How To
PostPosted: August 7th, 2007, 17:06
Hi All,
Alternative Forums Say That You Need "V-Tools" A Factory Maintenance Software For Doing The Same .I Managed To Get a Copy of the Same To Tryout .the Issue Is that We Also Need Specific Burnscripts .Which Are Specific To The Model/Disc And Head.Can Someone share the Burnscripts .Are these Same As ACE .Ace Only Has Burn Code ,Main Code, Downsize code .Very Confusing ....Help ?
PostPosted: August 7th, 2007, 22:35
For victor family dosent need Specific Burnscripts, you can disable bad head use vtool, but after done that you must open cover then cut head 0. if disable another head dosent need cut only head 0.
wawalab
PostPosted: August 9th, 2007, 12:41
u mean physically cut head 0 , with cutter ?
PostPosted: August 9th, 2007, 13:22
Hi wawalab,
I think you are wrong here i am not saying the cutter trick or anything.Indeed the victor has specific burnscripts and that also for specific heads and also for specific head numbers .Please Pm me i can send you a document for the same .
PostPosted: August 11th, 2007, 15:31
Can Someone share These Burn scripts That V-Tools Uses .It Will Help Me Immensely
PostPosted: August 22nd, 2007, 18:06
Hi Guys ,
Only1 Person Replied ?
Users browsing this forum: Google [Bot] and 101 guests
